Body kit pictures
Body kit pictures
Here are some pictures off the latest body kit/suspension project.
The front will be a SLA setup with 13" brakes with at least 17"X9" wheels and 275/40/17 tires, I might run a 17"X10.5" wheel with 315/35/17 tires. The rear is undecided, but I can run 335/35/17 tires on a 17"X12" wheel.
Re: Body kit pictures
Wow! This car is quickly becoming one of the most obnoxious (in a good way) XR4Tis on the planet. Any idea what/where you'll be sourcing the SLA setup from? Don't let anyone accuse you of going underboard. You've clearly gone overboard!youngfg wrote:The front will be a SLA setup with 13" brakes with at least 17"X9" wheels and 275/40/17 tires, I might run a 17"X10.5" wheel with 315/35/17 tires.
The SLA will use a SN95 Mustang spindle so it will be easy to get huge brakes and tires. I will make a adapter to put a upper ball joint where the strut used to connect. I tracked down some extended lower ball joints from Howe racing to help get the lower control arm down lower so it will make the LCA's easier to build.
The rear is undecided, I don't know how low I can get the rear suspension down to and it still work correctly. Grayson and I have worked out a way to offset bore the lug nut holes on Scorpio hubs to get them to a standard bolt pattern. So I may keep the IRS. If I can't keep the IRS I most likely will go with a cambered 9" ford rear end.
- KingpinCEO
I know some wet the bed thinking about the Thunder Saloon wide body, but I just don't like it no matter if it's on a real cossie or an XR. I know, I'm probably the only one but oh well.
Erik AKA MerkurSport's Bill payer. www.Merkursport.com The virtual Garage. Bring your own nudie calendar. You can now find MerkurSport on Facebook! http://www.facebook.com/pages/MerkurSpo ... 5756984607
I'm not a huge fan of it either. The whole setup is a little too visually extreme for me and it really smacks of the 80's. I do tend to like it more on a car that is done up in racing livery than on a car that is one solid color and no other interest.fastmaul wrote:I just don't like [the Thundersaloon body panels] no matter if it's on a real cossie or an XR. I know, I'm probably the only one but oh well.
At any rate, it makes monster tires easy to do. In fact, from what I've heard and seen of it, it might make it hard to get tires that are wide enough! I'll take it as a function-over-form creation and leave it at that. I'll be doing flares when I'm ready for 245s.
As far as widebodies go, the Thunder Saloon is very reserved in its styling... well, once those disgusting strakes are removed, that is.
All in all, it's not bad... just a little crazy for a street car.
Instagram @colinrdoyle
File to fit, paint to match.
Yep Agree with you both Anglin and Colin...
I'm guessing that the best and easiest to do to get those super wide tires would be to go that route?
I think the Thundersaloon shoulld be either a very clean, almost show car look (like Widebody XR's) or a straight up race car.
Anglin the 245's are they for the front or rear? (forgive the question...It's late and I can't sleep LOL..grrrr)
Even more reason. What's wrong with the 80s? It is the most awesome era and we are driving 80s cars, designed in the late 70s. First of the jellymold cars.anglin wrote:I'm not a huge fan of it either. The whole setup is a little too visually extreme for me and it really smacks of the 80's.
I'm gonna put on my Raybans now & my Miami Vice outfit before I go out with my Testarossa.
Both front and rear. That size tire should provide excellent grip, moderately priced light wheels, and not require hugely extensive work to make them function. The rear should be easy. The front is going to be significantly harder, but still doable.fastmaul wrote:Anglin the 245's are they for the front or rear?
The 80's were just an ugly time. Fashion, hair styles, car (and body kits) with strakes and breakdancing (I remember a breakdancing exhibition during the 7th inning stretch at an Astros game, for pete's sake). The 80's were so ugly that the ugly bled over into the early 90s. BTW, the Raybans are my poster child for 80's ugly. Everytime I think of Raybans I remember that guy on the commercial doing his freestyle rap about the Raybans. No, wait, that was Blu-blockers! See! The ugly just mashes together into one big lump in my head.XR4Timan wrote:What's wrong with the 80s? It is the most awesome era and we are driving 80s cars, designed in the late 70s. First of the jellymold cars.
