NEW Merkur part of the week
Choochoochoo
Re: NEW Merkur part of the week
Post by Choochoochoo » Fri Jan 08, 2016 1:22 pm
From what I've read, boost hits around 3500(I think) but will push up to about 35psi and pulls like a freight train...
2008 Mercedes Benz R320CDI
1985 Merkur XR4Ti
Post by merkurdriver » Sun Jan 10, 2016 6:25 pm
Robert Urfer wrote:Hey Mike,
What is the advantage of the HY35 turbo?
More power? Is it full of lag?
I am in the engine build stage now of my car and i'm looking for some ideas.
More power... more efficient power to be more specific. Full boost potential at 3600 RPM with good airflow in and out of the cylinder head. ( Keep in mind, the stock XR only gives 10 psi until the computer activates be BCS to 15 psi beyond 4200 RPM ). HY35 are happy to go up to 30 psi + reliably all day -- this turbo is capable of delivering double the psi over the stock T3 at the same RPMs.
Here's an XR dyno run with the HY35 putting down 322 HP to the wheels and and 361 TQ. This is a daily driver with a STOCK VALVE SIZE cylinder head.
Post by merkurdriver » Sun Jan 31, 2016 6:11 pm
Sierra RS Cosworth Hatch decal in black:
http://www.ebay.com/itm/NEW-Ford-Sierra ... 1510409144
Sierra RS Cosworth Hatch decal in silver:
http://www.ebay.com/itm/NEW-Ford-Sierra ... 1510409754
Complete XR / 2.3T Ford Turbo Mounting Gasket Kits only $9.95 with free shipping:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1790277527
(used) 1989 XR4Ti Coolant Bottle (with new cap):
http://www.ebay.com/itm/1989-Merkur-XR4 ... 1790989831
Also at http://www.merkurdepot.com we have 2.3 alternator relocation kits back in stock as well as new slotted & plated rear rotors for the rear disc brake swap.
amarthfea
Post by amarthfea » Thu Feb 04, 2016 6:29 am
Does that aftermarket hy35 come with any warrantee of any kind? Maybe a year or two or anything. Does it use a holset centre section? Curious for rebuild-ability.
I got a spare e6 (my current ported e6 is cracked) I can throw on out on this hy35 with the matching downpipe from you and that would be pretty good for 18 psi. What about oil lines? Do you recommended stingers holset braided return line? Already running a braided feed line and think that should still work.
- Adam -
~ HY35, FMIC, Header, MS, and moar 2.3 Go fast goodies... Now this car is moving! ~
Post by merkurdriver » Thu Feb 04, 2016 6:22 pm
90 day turbo warranty with (crossing my fingers) everyone properly installing it as a new turbo; removing the coil wire and cranking the oil pressure up and lubing the turbo before first start-up, etc. etc. I will stock rebuild kits soon as well, FYI.
The stock oil drain line will hook right up to this turbo and that's what I'm running on one of the cars here. The oil feed is one size up if I remember correctly - if you already have a braided feed line you might need an adapter from stinger at most.
Post by merkurdriver » Tue Mar 01, 2016 10:48 pm
NEW Style Ford logo XR4Ti Key Blanks:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1526101074
NEW Style Ford logo Scorpio Tibbe Key Blanks:
http://www.ebay.com/itm/NEW-RARE-FORD-M ... 1809687489
Since the Ford Transit is now sold in the US many Ford dealerships and independent locksmiths now carry the equipment needed to cut Tibbe key blanks, so getting a key cut for your Scorpio is much easier than it used to be.
(Call around locally and ask about cutting a "Ford Tibbe Key")
helios
Post by helios » Wed Mar 09, 2016 12:22 pm
Nice, I'll probably look into picking up a couple of these this weekend if I remember.
-Chris S.
'76 Mk1 Swallowtail / '87 XR4Ti slickroof / '93.5 Corrado SLC / '94 SVT Cobra / '95 Escos / '96 GTi 2.slo
Post by merkurdriver » Thu Apr 07, 2016 10:13 pm
NEW NOS Merkur XR4Ti 4 Piece XR4Ti Logo Floor Mat Set:
http://www.ebay.com/itm/201557447223
NEW NOS Merkur XR4Ti Right Side Front & Rear Floor Mats Gray:
http://www.ebay.com/itm/201557454620
(used) Merkur Scorpio Ford Floor Mats Front Set Black Embroidered Scorpio Logo:
http://www.ebay.com/itm/201557466645
NEW Remanufactured LA3 ECU:
http://www.ebay.com/itm/191844054152
eaton53
Post by eaton53 » Fri Apr 08, 2016 6:08 am
Hey Mike...
The 4-piece are the correct mats for a Shadow Gray XR?
'89 XR4Ti
Post by merkurdriver » Fri Apr 08, 2016 8:54 pm
eaton53 wrote:Hey Mike...
Its the darker of the 2 factory grays, that's all I can say for sure. Factory part # is there if anyone has access to Ford part # database to verify, the only thing the label on the box states is "GRAY".
eaton53
Post by eaton53 » Fri Apr 08, 2016 9:18 pm
Thanks Mike...
They look similar to the old mats I already have. Computer monitors are tricky when it comes to color.
I also wonder about how picky dealers were on mat options. You got a gray interior, here's some gray logo mats, have a nice day.
'89 XR4Ti
Post by merkurdriver » Fri Apr 08, 2016 9:23 pm
They look similar to the old mats I have. Computer monitors are tricky when it comes to color.
I also wonder about how picky dealers were on mat options. You got a gray interior, here's some gray mats, have a nice day...
They have an E8 part #, so that's 1988 and up at least. That eliminates the lighter gray ones from 1985-1987 at least (E5 part #...)
If you have a smart phone you could look at the auction on the phone as well to get a second screen view. Outside of that the Ford part # database would be the next best bet if you had access.
Post by merkurdriver » Thu Apr 14, 2016 10:54 pm
NEW NOS VAM Air Meter XR4Ti / 2.3T Ford:
http://www.ebay.com/itm/191848925897
NEW NOS XR4Ti Floor Mats:
http://www.ebay.com/itm/191848919911
eaton53
Post by eaton53 » Tue Apr 26, 2016 6:00 pm
Got the mats yesterday, hit both fronts with some carpet cleaner and now the driver looks as good as the passenger.
Mike shipped those suckers out fast!
Now that I have some OEM mats to compare, I've discovered that my old mats are replicas.
'89 XR4Ti
Post by merkurdriver » Mon May 02, 2016 1:57 pm
NOS NEW AC compressors for XR4Ti and Scorpio:
http://www.ebay.com/itm/201575294352
NEW Remanufactured LA2 Ford 2.3 Turbo Coupe 5spd Engine Computer ECU:
http://www.ebay.com/itm/201565016478
Refurbished Ford 2.3 Turbo Script Valve Cover:
http://www.ebay.com/itm/191856238652
Also a coupe rotated intakes have also just arrived from the machinist and are now available/in stock at http://www.merkurdepot.com
