The Merkur Club of America Forums • Rear disc brake kit 11" NEW DESIGN - Page 7
Page 7 of 13
Re: Rear disc brake kit 11" NEW DESIGN
Posted: Mon Dec 12, 2016 12:56 pm
by merkurmaniac
How do I go about ordering a set of brackets and cables ?
Thanks,
Richard
Posted: Tue Dec 13, 2016 12:45 am
by timxr8
merkurmaniac wrote:How do I go about ordering a set of brackets and cables ?
Thanks,
Richard
Just shoot me a PM and I'll get you my paypal address. Usually in the mail the next day.
Posted: Thu Dec 15, 2016 11:33 am
by megasquirt33
I am interested and i know a buddy who would also be up for a set.
Posted: Sat Dec 17, 2016 6:52 am
by timxr8
megasquirt33 wrote:I am interested and i know a buddy who would also be up for a set.
Cool, shoot me a pm and I will give you my paypal address. $80 shipped for just brackets and hardware, add $60 for a parking brake cable.
Posted: Wed Jan 04, 2017 3:04 pm
by cmouta
What are people doing for brake hoses?
Posted: Wed Jan 04, 2017 9:34 pm
by merkurdriver
cmouta wrote:What are people doing for brake hoses?
These DOT approved braided stainless lines will work with Tim's set up (as well as Scorpio / Cossie calipers).
http://www.merkur.50megs.com/photo3.html
Posted: Thu Jan 05, 2017 1:03 am
by timxr8
^^^^^^^^^^What he said^^^^^^^^^^^
Posted: Sun Jan 15, 2017 9:34 pm
by In XS 7
Hey Tim, I have a question do I need to upgrade to the Scorpio master cylinder to have the rear disc upgrade on my 89' XR4Ti? or The master cylinder on my 89' XR is good enough? also, do I need to remove the proportional(or whatever it is called) valve or gutted it?
:cheers
Posted: Wed Jan 18, 2017 12:56 am
by timxr8
In XS 7 wrote:Hey Tim, I have a question do I need to upgrade to the Scorpio master cylinder to have the rear disc upgrade on my 89' XR4Ti? or The master cylinder on my 89' XR is good enough? also, do I need to remove the proportional(or whatever it is called) valve or gutted it?
:cheers
You'll be ok with the Stock master. Even the early one will be fine (stock Focus uses the same dia master as the early XR). As for the prop valve, I would either gut it, or get rid of it. Since it's a smaller diameter piston in the Caliper, it'll increase clamping pressure more progressively.
Hope that helps.
Posted: Wed Jan 18, 2017 8:38 pm
by In XS 7
:thumb Great, Thank you very much Tim. :cheers
Posted: Sat Feb 18, 2017 12:11 am
by timxr8
Finally had Jeff Esteban over to put a set on his car. I'll let him reply with his thoughts on the performance of it.
If you have drums, remove everything from the rear bearing carrier. Requires removal of the rear hub (41mm/1 5/16" socket for axle nut). It's torqued to 240ft lbs, so requires a lot of force. You will reuse the bearing carrier bolts. The top 2 are used for the bracket (pictured below).
I didn't take as many pictures as I should have, but next you put the rear rotor on the hub. Then, you can do 1 of 2 things. Either take the caliper bracket and mount it to the adapter bracket, or assemble the caliper completely with the pads.
If you just mount the bracket, make sure you take the slide pins out and put them into the rubber bushings of the caliper. Place the pads on the bracket with the spring on the inner pad. Place the caliper on the bracket/pads and screw in the pins to the bracket. Take the spring part that goes into the outside portion of the caliper and under the bracket to pull the caliper and outer pad down.
These are 2 lbs lighter than the Scorpio 280mm setup from MC2. Not that much of a difference, but here's a big part: The pads are significantly larger and there are endless pad choices.
The MerkurDepot hoses are required to go forward around the spring and then straight back into the caliper as the hose connection is in the front. The cable from the Sierra works perfectly and simply requires adjusting the sheath on the underbody of the car.
Overall, great success.
Posted: Sat Feb 18, 2017 7:34 pm
by merkurdriver
looks good :cheers
Posted: Mon Feb 20, 2017 2:39 am
by timxr8
Adapter fittings to fit into both the caliper and the hard line on the car are M10x1.0. I have always used the ones from Russell, which come in pairs and are nickel plated. R41431
Hose length I would recommend is 24" for clearance around the spring. Mike's (Merkur Depot) will work, but ensure it remains clear of the spring so it doesn't get caught between a couple coils. AFCO makes some really nice Kevlar ones, but you can get the Russell DOT ones too:
AFCO 6684053-24
Russell: 656062
On Jeff's we used a pair of the Russell DOT 15" with a 90 deg end. The trick is ensuring there is clearance from both the spring and from the spinning axle.
Posted: Fri Feb 24, 2017 3:55 pm
by cmouta
:headbang
Posted: Fri Feb 24, 2017 6:44 pm
by John Brennan
Question:
It seems to me that a lot more stiffness and strength could be realized by extending the bracket sides down to include the lower bolts on the hub. Mike's adapters for the T-Bird rears go full circle here, and most Scorpio rear adapters go down at least on one side. Anyone else think this would be a good measure against flex?
I think this is a terrific and well-researched solution, but this is the only thing I wonder about.
