A Variety of Parts for sale. Carlisle Delivery Free!!
jkxr4ti
Post by jkxr4ti » Wed May 31, 2017 12:18 pm
I have a bunch of parts up for sale here, most have been sitting for some time in garage storage and look to be in good shape. All David Godfrey parts and kits that are new as well. Willing to deliver to Carlisle for no extra charge, or ship to you at actual shipping costs. Thanks for looking and offers considered!
Photos of actual parts can be seen here: https://goo.gl/photos/Pnz9qXuKh6VVXBq8A
1 Set of DG PBR Mustang front caliper adapter brackets. Comes with a set of brake lines. $125 As detailed Here: http://www.key-ideas.com/DG-PBR-Front-B ... grade.html
1 Set of Turbocoupe DG rear disk adapter brackets, new style without backing plate mounts These have spacers for caliper brackets. $50
2 Sets of DG rear disk adapter brackets older style with the backing plate mounts. These dont have spacers for the caliper brackets and not sure if those are required or not. $40 each pair. As pictured in this writeup: http://www.key-ideas.com/DG_RearBrakeUpgrade.htm
1 left 1 sold DG Supercoupe Master cylinder adapter bracket kits. These come with the plate, pushrod adapter bushing, and a brake line T fitting. $75 each. Details here: http://www.key-ideas.com/DG_MasterCylinder.htm
2 left 1 sold DG Manual Clutch adjusters. These are the older style units that mount to the plastic clutch eccentric instead of replacing it. $100 Each. Details on the swap and part here: http://www.key-ideas.com/DG_ClutchAdjuster.htm
Sold Kit of DG manual camber adjusters. These go where the inner Control arm bolt is located and requires modifying your front cross member to install them. $125 Details on the kit here: http://www.key-ideas.com/DGCamberInst2.htm http://www.key-ideas.com/DG_CamberAdjuster.htm
2 sets of DG hood prop kits. These allow you to ditch the stock prop rod and have a gas shock hood. New $75 Each
1 XR4 E brake Cable, new but modified and shortened for TC rear discs $50
2 LA3 Computers, used $50 Each. Sold
2 TC Rear calipers and sliding pin brackets for TC rear disk conversion, used but in very good shape $100 or $75 if included with DG brackets above
2 CV Boots $15 for both or $10each
1 new Gillis Boost Controller(missing bottom vacuum fitting) $20
4 Metal Key Blanks $10 Each
1 TPS Test and calibration harness $25
1 Rear Camber shim kit(not sure the original seller has some generic instructions) $10 Sold
1 Clutch Cable, new $20 Sold
1 Set PBR take off calipers with Brackets(could combine with brackets above to make a full kit minus rotors) $50
1 FMS multi-index cam sprocket. Fixed advance or retard in 2 deg increments but requires removing the sprocket to adjust. $50
1 Set of Rear spring spacers, Good to restore some ride height to sagging stock springs $10
1 Motorcraft Timing Belt tensioner pulley new $60 Sold
1 Motorcraft TFI new in box $75 Sold
1 Motorcraft TPS new in box $75 Sold
1 Aftermarket auto trans modulator valve $15
88-89 Basket Wheel Locks (No Keys available to sell but have been checked with one) QTY 10, $75 each or $250 per set
88-89 Basket Wheel Center Caps used, Most are in very good condition without peeling and a couple have a few scratches. $20 Each or $60 per set of 4
2 AC Compressors New/Rebuilt in the boxes, No clutches on these $200 each
1 new 3” SVO Downpipe some surface rust from sitting, not sure if this would fit the XR but it looks like it would come close. Has the stock style turbo flange. $100
1 Set of new Sierra smooth steering column and gauge bezels $200
JimG
Re: A Variety of Parts for sale. Carlisle Delivery Free!!
Post by JimG » Thu Jun 01, 2017 5:59 pm
I'm interested in an LA3 and the rear shims. Will see you at Carlisle
Jim Gosses
jkxr4ti
Post by jkxr4ti » Thu Jun 01, 2017 9:19 pm
Sounds good Jim!
ford.scorpio
Post by ford.scorpio » Thu Jun 01, 2017 10:18 pm
Good evening; I will take the other LA3......
jkxr4ti
Post by jkxr4ti » Thu Jun 01, 2017 11:07 pm
Ok you've got dibs on the second one. See you guys tomorrow evening. Safe travels!
sponge003
Post by sponge003 » Fri Jun 02, 2017 1:03 pm
I am interested in the following, will need shipping to 28027
1 DG Supercoupe Master cylinder adapter bracket kits. These come with the plate, pushrod adapter bushing, and a brake line T fitting. $75 each. Details here: http://www.key-ideas.com/DG_MasterCylinder.htm
1 DG Manual Clutch adjusters. These are the older style units that mount to the plastic clutch eccentric instead of replacing it. $100 Each. Details on the swap and part here: http://www.key-ideas.com/DG_ClutchAdjuster.htm
1 Kit of DG manual camber adjusters. These go where the inner Control arm bolt is located and requires modifying your front cross member to install them. $125 Details on the kit here: http://www.key-ideas.com/DGCamberInst2.htm http://www.key-ideas.com/DG_CamberAdjuster.htm
jkxr4ti
Post by jkxr4ti » Fri Jun 02, 2017 11:25 pm
Sponge, the rear shims are spoken for by Jim but if he changes his mind I'll let you know.
The other items are still available at this point.
reddy2300
Post by reddy2300 » Sat Jun 03, 2017 2:08 pm
What's your price on the front PBR caliper mounts? Will need shipped or handed to Jerry at Carlisle.
1987 5-speed XR4ti-70K mile "barn find", Rosso Red, Grant wheel, short throw shifter, PE/big VAM, 255lph pump, 3" Stinger/Magnaflow exhaust, MD "shorty" radiator/IC, "Pony" wheels, Koni Yellow, Rapido sway bars, poly/aluminum bushes, Gillis valve,
jkxr4ti
Post by jkxr4ti » Sun Jun 04, 2017 1:51 am
$125 on the pbr mounts with lines.
Also updated the list with prices and sold items.
jkxr4ti
Post by jkxr4ti » Sat Oct 21, 2017 4:39 pm
Still have many items for sale. Updadted the list with current availability.
jkxr4ti
Post by jkxr4ti » Sat Oct 21, 2017 9:51 pm
It looks like Ed Keys site is down since I added the links originally.
Not sure if it will be back or not but you can use this link to get to the archived content:
http://web.archive.org/web/201608111343 ... eyPage.htm
dunhamr1
Post by dunhamr1 » Mon Oct 23, 2017 11:44 am
Is the Gillis valve still available, I'd be interested.
-Ryan Dunham
1989 Merkur XR4Ti, Radiant Red, 5-speed (T9), LA3/big VAM, Stock T3 w/ Cosworth hot side - nickname: "SheaXR4"
Daily: 2003 VW Golf MkIV TDI, 199k mi
jkxr4ti
Post by jkxr4ti » Mon Oct 23, 2017 10:00 pm
I have someone tentatively interested in the Gillis valve so your second in line for that Ryan. I'll let you know.
WINDI
Post by WINDI » Tue Oct 24, 2017 7:39 am
Sent you PM about rear brake adapters' front and rear brake calipers and parking brake cable
jkxr4ti
Post by jkxr4ti » Wed Oct 25, 2017 8:30 pm
Ryan, the gillis valve is available if your interested still. I can do 25 shipped via Usps.
