WTB: T5 for XR
XR4Ti cars and parts - Please state your asking price and item location. Preface wanted ads with "WTB" in the subject.
JimG
WTB: T5 for XR
Post by JimG » Wed Nov 29, 2017 7:17 pm
Since my T9 deep sixed, I'm looking for a t5 with good gears for my XR and preferably ready to go.
Jim Gosses
86 XR4TI, 165K, IC, RR, PBR Fronts, T-bird Rear Discs
reddy2300
Re: WTB: T5 for XR
Post by reddy2300 » Thu Nov 30, 2017 5:58 pm
And a bellhousing, clutch plate, drive shaft, trans mount, etc.
It's not a "same for same" swap.
1987 5-speed XR4ti-70K mile "barn find", Rosso Red, Grant wheel, short throw shifter, PE/big VAM, 255lph pump, 3" Stinger/Magnaflow exhaust, MD "shorty" radiator/IC, "Pony" wheels, Koni Yellow, Rapido sway bars, poly/aluminum bushes, Gillis valve,
Longitudinal
Re: WTB: T5 for XR
Post by Longitudinal » Thu Nov 30, 2017 9:14 pm
I have a TC T5 and bell housing with release fork. Make a deal and I will box it up and ship it to you this weekend.
timxr8
Re: WTB: T5 for XR
Post by timxr8 » Fri Dec 01, 2017 1:22 pm
Are you happy with the gear ratios in the T9? Have you done any research into the swap? Looked at which T5 you would like (Over 5 different Ford ratio configurations)?
4 cyl have a few: (First gear/OD) 4.03/.82, 3.97/.79, 3.5/.8
V6/V8: 3.35/.73, 3.35/.68
V8/Motorsport: 2.95/.8, 2.95/.63
Then you can mix and match to create your own if you want. I am building a 2.95/.73 (just like the F-Body V8). Many aftermarket gears now to do a .8 in the 2.95 box.
Don't forget to align the bellhousing. Especially if using an adapter bushing to fit a V8 trans.
JimG
Re: WTB: T5 for XR
Post by JimG » Fri Dec 01, 2017 2:23 pm
Tim, I always thought that with the T-9, First gear was to short and third gear too long. It seems that the 2.95 1st would be more driveable bringing all gears closer together and improving the transition from 1st to 2nd
Jim Gosses
mopman93
Re: WTB: T5 for XR
Post by mopman93 » Mon Dec 04, 2017 8:53 pm
I have a T5Z motorsport box and a 300zx tailhousing that puts the shifter in the same place as the cosworth. PM me if interested.
