86 xr4ti. Azure Blue. Grey leather interior.
Heavily modded.
3.64 Detroit Truetrac clutch style LSD
Rebuilt axles, new cv boots
Fully adjustable rear beam, powder coated black
Poly beam and STA bushings
TC rear discs with parking brake adapters
Koni reds in back
Cosworth rear sway bar
Tilton firewall mounted brake bias assembly and hydraulic clutch has remote adjuster
Recaro trophy seats
Cosworth steering wheel
Rapido carpet
Compbrake Compression struts
4x4 crossmember
4x4 hubs and knuckles rebuilt
4x4 custom stub shafts for 2wd
4x4 escos rotors and calipers
EsCos front control arms
EsCos LHD steering rack
EsCos Group N Bilstein coilovers fully rebuilt and custom valved for an xr with digressive valving and 125lb springs
JVAB rose jointed top mounts
Cosworth strut bushings
Euro headlights with Yellow fog reflectors
OEM cosworth 2wd radiator with fans
OEM cosworth air box
Cosworth Grille
16x7.5 OZ Fittipaldi wheels with brand new 205/50/16 BFG sport comps
Car is currently a roller. Was setup with a 2.0 duratec with itbs. This can be sold separately or with the car.
I'd be interested in getting rid of the whole thing. If I were to part it out I'd probably end up keeping the escos parts since they were such a pain to get.
Small rust at the lower lip on the hatch, same with the drivers door. Rocker panels could use some love but are better than most xrs out there. Car is located in central CT.
Please pm me and we can discuss.
