How to attach sunroof console when OEM clips are broken
Bob Weir
Post by Bob Weir »
Secure front of sunroof console to roof. [When one or both OEM plastic clips have broken].
The Scorpio has an unused bracket in the front center of the opening for the sunroof console. Use a speed nut and screw to secure the “bridge” to the car’s bracket.
To make the "bridge", use any sheet metal about 2” long by 1” wide. Bend and/or cut it to the appropriate shape / size. Secure the “bridge” with a screw to secure it to plastic console. [I used a “J” clip, secures the rain spouting to a building.]
While you have it apart, change the sunroof switch to an ILLUMINATED switch.
viewtopic.php?f=29&t=27876&p=257338#p257338
ford.scorpio
Re: How to attach sunroof console when OEM clips are broken
Post by ford.scorpio »
Just used your idea; thanks!
Father Adam
Post by Father Adam »
Nice write up Bob, cheers! :cheers
1989 Ford Granada Scorpio
http://adamsgranadablog.weebly.com/
Bob Weir
Post by Bob Weir »
Now that we can post photos directly in a forum, here they are:
Console bracket 1sm.jpg (43.08 KiB) Viewed 4802 times
Console roof opening sm.jpg (38.96 KiB) Viewed 4802 times
john keefe
Post by john keefe »
Thanks. Great idea. Works perfect!
