Hi
If either the Temperature Blend Door Motor or Air distribution Door Motor fails and are replaced how do you realign the gears so that the EATC module
can properly position the doors? In my case the Distribution motor failed and just shrieked and gave a 16 trouble code. I'd imagine the vent motors may also have a similar alignment problem when they fail.
thanks
Scorpio EATC motor gear alignment
Larry with Five XR4s and Two Scorpios
