Coolant bypass.
Coolant bypass.
The 2.9 in the Ranger has no bypass hoses and uses the heater as a bypass. Is there a reason the Scorpio uses them ?
The reason I ask is the timing chain cover on my Scorpio 2.9 has very badly corroded through hose fittings and I want to simply weld them shut.
Just thinking out loud.
http://bayimg.com/kAiacAAGk
Cleat
Cleat
Re: Coolant bypass.
You mean...the coolant flow is continuous through the core?
Blasphemy...
Blasphemy...
Re: Coolant bypass.
Cleat, I would look for a good used cover. Either in the local yards or keep eyes peeled on Ebay or Craigslist
..or perhaps a board member here can sell you one.
I say this for two reasons:
1) You may have other areas of corrosion on the cover that could become a concern later on..
2) You are only asking for trouble when you start disabling the heater/bypass.
Re: Coolant bypass.
I am not bypassing the heater (a needed item here in Canada) only the bypass hose to the water pump from the lower intake.
It was done on all Ford Rangers so I don't see the problem (not that there isn't one). The hearer control valve has been deleted already.
This is a 2.9 Scorpio engine transplanted into a 1985 XR4Ti.
Re: Coolant bypass.
Bumping this thread as I'll be doing a coolant system "update" on the Scorpio this spring. I'm all about simplifying things, so the HCV will be getting ditched for sure. Wondering about the coolant bypass hose discussed herein and if/how that could be ditched.
Re: Coolant bypass.
Trying to figure the Scorpio coolant flow strategy. Pics below are from my partScorpio which is a '89 factory 5-speed. Is the capped off fitting on all Scorpios or is this just a 5-speed thing?
Re: Coolant bypass.
It's an '89 model change (auto and manual trans).
Re: Coolant bypass.
Hmm, so did the Scorpio basically go with the Ranger 2.9 strategy but instead of going with the Ranger cover they just capped it off? Ranger cover below....
- andyofcolumbusmerkur
- Level 6
Re: Coolant bypass.
I had an old Jeep, and previous owner had installed two pieces of garden hose going from the engine straight to the heater core. It was an open top/bikini top cj7 and it was still uncomfortable in the summer with that hot coolant flowing around near your legs. I've seen people put some valves near the firewall on an xr with bypassed control valve, at least you could shut off the flow in the summer if needed. I think as long as there was some flow going around the closed thermostat, like out the 1/4 inch sized hose at the filler neck, you would be fine and not hurt the engine. I'd imagine the ford engineers were concerned with a hot spot starting near the combustion chamber, before the thermostat had a chance to open. You know how people drive, starting a completely cold engine and immediately flooring it, 45 seconds later doing 90 on the highway.
"Excellence does not require perfection." H.James
Re: Coolant bypass.
Myself and others have run without a HCV in a XR for years. No issues. My Alfa 164 came without a HCV from the factory. No issues. Sure, there's going to be some incremental heat that transfers into the cabin, but with the flapper valve closed, the effect is minimal.andyofcolumbusmerkur wrote: ↑Wed Mar 04, 2020 9:41 am I had an old Jeep, and previous owner had installed two pieces of garden hose going from the engine straight to the heater core. It was an open top/bikini top cj7 and it was still uncomfortable in the summer with that hot coolant flowing around near your legs.
But that's not the focus of the conversation here. We're talking about the coolant flow through the front timing cover. Look at my pics above. Looking at BAT's old catalog, this isn't even indicated at all.
Re: Coolant bypass.
Stopped off at a junkyard on the way to Carlisle last month and came upon a '89 2.9 Ranger that was significantly disassembled. I knew this was my chance to get a front cover, so I went to work. Even with all that was removed, it was no walk in the park. The crank pulley had likely never been off the engine in 30+ years so it took a lot of work with a hammer and pry bar. Thankfully I didn't need that since I killed it in the process. In the end success....
Here's what I found.... And here's what I ended up with after a significant effort with the power washer once home...
Re: Coolant bypass.
If there is something off a Scorpio that you're looking for, let me know.
I've got one here that I am taking apart as it's rusted out.
Re: Coolant bypass.
Thanks, but I've got a parts Scorpio here as well. The front cover off the Ranger 2.9 is different - that's why that needed to be the donor. I still haven't researched enough the differences between the coolant routing on the Ranger and Scorpio to know for sure if I'll even use this, but there's a good chance I will so I had to seize the moment.
Re: Coolant bypass.
I haven't done anything on researching the use of the Ranger 2.9 front cover, however, driving the Scorpio a couple times lately in colder temps I have been impressed with just how quickly the heat comes up. In fact, I'd say it's faster than any vehicle I own, some of which are much more modern rides. I'm wondering if perhaps the different plumbing of the Scorpio (vs. the Ranger) is responsible for this.
Just a thought...
Just a thought...
Re: Coolant bypass.
I agree re the Scorpio heat, but I find the XR heat comes up quite readily too.
