Silly question(s): Do the Scorpio & XR use the exact same CV joint? The Scorpio axles longer, right? Some sources list them exactly the same, but IIRC STA cross-member is wider for the Scorpio, thus longer shafts...
Mic'd as best I could on the car, and it appears the Scorpio's are 100mm x 87 bolt centerlines, which should be the same as XR, unless the splines are different. But can't find an application or source anywhere specifically for, or compatible with a Scorpio, and no cross-references/interchange info. Not much listed for XR either.
Curiously, the joint is stamped with the same part number as the HD Cosworth CV's (72GG-4635-AA), which are 108mm x 95(?) centerline x 40mm wide. Easy cross-reference to Porsche 930, but obviously don't want to be buying GKS bearings off that same part #. Looking up cross-references on UK sources, they seem to show the larger Cosworth size in that same part # also being used on Granada's & Scorpios.
Thanks!
CV joints/axles the same as XR?
Re: CV joints/axles the same as XR?
stub shafts are NOT the same.
half shafts ARE the same
rear control arms are NOT the same.
Jeff
Thanks Jeff. BTW, the parts you've sent me worked great!
- merkurdriver
( x 2 ) What Jeff saidblugg wrote:stub shafts are NOT the same.
Thanks Jeff & Mike et al.
This is my first Scorpio; it was in great shape, but sat for a few years. Now that its back on the road, 29 year old parts are starting to fail. Like starting from scratch trying to figure out solutions, but now I no longer have all the time in the world to figure it out, or do hours of searching like I used to with the myriad of XR's I've owned.
John
John
