Swapping in later EATC with "Off" switch
I've read that not only did the later cars get a EATC with an "off" switch, but there was actually a recall for this. I'm pretty sure I won't gt covered by the recall, but what's involved to swap in the later unit. Is it just a plug-n-play swap???
Re: Swapping in later EATC with "Off" switch
The EATC unit is easy to switch. Remove the IP valance or shroud, two screws hold the unit to the IP frame, disconnect the harness to the unit.
