Rear Wheel Well Liner alternative
Post by DPDISXR4Ti » Fri Jun 22, 2018 11:54 am
Several options from modern cars (Focus, Mustang, etc) have been used in the XR world, but has anyone fitted an alternative liner for the rear wheel wells of the Scorpio? Mine are crumbly and I just don't see them going back in.
On a related note, the Scorpio is more prone to rust than the XR in the forward area of the rear wheel well. I seem to recall there's been some discussion about the root cause of this and the best preventative action to take.
Re: Rear Wheel Well Liner alternative
Post by Ed Lijewski » Fri Jun 22, 2018 12:36 pm
I removed all four wheel well liners from my parts Scorpio thinking to install the rears on on the rear of an XR. I quickly gave up on that idea as the Scorp liners were heavy, very floppy and a pain to hold in place to begin installing (Mustang/ Focus liners are light, molded and hold shape on first step to mount and then attach at other points and then trim to fit). I gave the car with liners in the trunk to Jan Talian...he likely still has the liners. Those liners were intact, in like new physical condition (not a whit of crumblyness even hinted at).
In removing the rear liners (above) I could clearly see that the liners themselves did not allow for self-cleaning of crud and snow/salt/chemicals at that commonly seen rusting point. In installing either Scorpio liners or aftermarket ones, just trim enough of the liner along that fender edge so drainage and self-cleaning can occur. I'm sure tge solution is that simple (to correct a design oversight/error)
Post by DPDISXR4Ti » Sun Jun 24, 2018 12:45 pm
So have you installed Focus or Mustang rear liners in a Scorpio?
I'm also more of the school of thought that you can't ever fully block the bad stuff from getting in, so you're better off keeping it open and cleaning as often as possible. The strategy has worked on my F150 which are notorious for real wheel well rusting. I cut out the little bit of rusted area at the top of the wheel well and left the channel open. Now every time I power-wash the truck, I shoot my power washer in there. Admittedly it looks like hell, but it's a beater truck.
Post by Ed Lijewski » Sun Jun 24, 2018 3:04 pm
No. None needed on my Chestnut Brown Scorpio.
The OEM liners I removed above were impressively intact and flexible and had easily another 100+K or miles in them. You couldn't go wrong or do better than mounting them if Jan still has them.
blugg
Post by blugg » Mon Jul 16, 2018 4:25 pm
Perhaps the very early Scorpios had a different rear liner material. I’ve never seen front or rear sxorpio liners prematurely fail or crumble.
Jeff
Post by DPDISXR4Ti » Mon Jul 16, 2018 10:29 pm
Interesting thought and quite possibly correct. I'll have an opportunity to get a set from a '89. That's certainly the best bet from a fitment standpoint.
Post by DPDISXR4Ti » Fri Aug 03, 2018 1:57 pm
Installed rear Focus liners yesterday. Not my finest effort, and it's not a great solution, but it will suffice for now. Although the Focus liners are easy to cut and force into shape, I really don't like the material and the way it holds so much dirt. I think this will be a temporary solution.
morlynon
Post by morlynon » Thu Nov 29, 2018 3:00 am
Any pics? I'm curious how they look.
Post by DPDISXR4Ti » Thu Nov 29, 2018 11:40 pm
I didn't bother to take any pics. Next time I've got a rear wheel off I'll try to remember to have the camera handy.
As for the quality of the stock liners, I'm inclined to agree with Jeff's theory that the '87 cars got crap liners. My '89 parts car and the '89 I pulled rear liners from were both in very good shape, showing no signs of crumbling.
