Scorpio / Sierra plenum and throttle body parts / questions
Re: Scorpio / Sierra plenum and throttle body parts / questions
Post by brokencase » Wed Jun 12, 2019 10:52 pm
Doesn't make any sense... If your putting on the Eaton M62 Supercharger, then what would you want the Scorpio intake for?
I'll believe the Eaton on the 2.9 when i see it. It's not bolt on - You need to start welding up some aluminum and cranking up the Bridgeport before you even get close.
Post by my8950 » Sat Jun 15, 2019 2:47 pm
PetroleumJunkie412 wrote:
Thu Jun 06, 2019 7:32 am
Should be near the front of the block around the timing cover.
Curious if the high compression block ever made it into the USA. Nor sure if it did, but I know very little about Merkur.
Reference:
http://www.ford-ig-wriedel.de/technik/v6_motoren_s2.htm
Heads have the casting number on the side. 86tm are the unstable ones, 89tm are improved, and World Products are the bulletproof ones.
If interested, PM me a phone or email and I can send some photos. Engine is complete in car, so it’s not easy to get to these areas.
