Scorpio A/C orifice tube location?
Post by brokencase »
I am about to do an A/C compressor replacement. Plan on doing the "Full Monty" complete system flush, new expansion valve, new orifice tube, dryer etc...
I bought the expansion valve and orifice tube on the cheap from RockAuto. Remanufactured compressor was a promo off of ebay at $95.
However I can't find out where the orifice tube goes. It is not mentioned in the Helm's manual.
PeterP11c
Re: Scorpio A/C orifice tube location?
Post by PeterP11c »
Found this video regarding orifice tube removal. Not exactly what you asked for but it might offer some guidance.
https://www.youtube.com/watch?v=QIf9FNwctSg
Good luck.
Peter P11c.
I wonder if it is inside that line that has the coupling down low on the driver's side. In the past I've separated and replaced a leaky o-ring at that connection but I never looked inside the line to see if there was anything in there.
A/C systems (at least our vintages) used either expansion valves or orifice tubes, not both. Merkur Merkur a/c systems use expansion valves, only.
[That coupling/hose ends aside the compressor have nothing in it.]
That's what I was thinking Ed. This is another case where RockAuto sells something that does not apply to the Scorpio.
No big deal as it did not cost much. Got a good price on the expansion valve.
I guess I will start a new thread as I perform the A/C overhaul.
