Volvo Fused Power Distribution Box & Refreshing Major 12V Connections
Re: Volvo Fused Power Distribution Box & Refreshing Major 12V Connections
This is all very cool, and makes me embarrassed of the mess my connectors seem to be. I think I've got Brad's old style w/ the Ford stamp, but turned upside down, wires hanging all over the place w/ corrosion on the connectors. Another project/preventative measure sometime. I tried hooking up the 12V adapter kit I used to fix the speedo, this time to test the rear passenger window motor... no voltage at all on any of the wires/connectors. Had to go pretty close to the battery posts to get any. I guess that's a problem waiting to happen?
Dug into the harness on the parts car today looking for splice S1004. As you may be able to tell from the pic, it's buried in that big wad of wires behind the instrument cluster, exactly in line with the steering shaft. All you should need to remove is the upper dash to get to it. As expected, the tape is all gooey, and then there's another wrap of gooey tape around the splice. As you can see this one was very clean and not corroded; I think I would just put some liquid tape on it and re-wrap it if I found it in this condition on the running car.
My memory on this is really fuzzy, but now that I look at your pic I believe I redid one of the splices underneath the dash (so not 1004). Some day soon I'll try to find the time to go out and take a look.DPDISXR4Ti wrote: ↑Wed Aug 10, 2022 10:39 pm Dug into the harness on the parts car today looking for splice S1004. As you may be able to tell from the pic, it's buried in that big wad of wires behind the instrument cluster, exactly in line with the steering shaft. All you should need to remove is the upper dash to get to it. As expected, the tape is all gooey, and then there's another wrap of gooey tape around the splice. As you can see this one was very clean and not corroded; I think I would just put some liquid tape on it and re-wrap it if I found it in this condition on the running car.
Dimitri in NYC
88 Scorpio 2.5 Turbo
89 Scorpio 4.6 DOHC
02 E46 330Ci
17 MKC
89 Scorpio 4.6 DOHC
02 E46 330Ci
17 MKC
I was thinking your description pointed to the splice being lower down behind the dash than S1004 is. Maybe S1009?
Now that I might have a little free time, I was going to check this. Brad, did you mean "upper dash" as in the steering column shrouds and the IC, or actually removing the complete, padded dash?DPDISXR4Ti wrote: ↑Wed Aug 10, 2022 10:39 pm Dug into the harness on the parts car today looking for splice S1004... All you should need to remove is the upper dash to get to it.
The complete dash pad. It's actually a much easier job on the Scorpio than XR, if you haven't ever done it before. If it's the first time coming out in 30 years, it will probably take more of a pull than you'd expect. It really needs an impact pull.john keefe wrote: ↑Sat Apr 01, 2023 1:31 pm Now that I might have a little free time, I was going to check this. Brad, did you mean "upper dash" as in the steering column shrouds and the IC, or actually removing the complete, padded dash?
The dash pad is secured in place at the windshield edge by two metal fingers of ~2" width, one on each side towards the lower corners of the windshield. When installed the fingers press on the dash pad, holding it securely. A firm tug releases the pad. A firm push on reinstall re-secures the pad.
- brokencase
I saw these recently and thought they might be a pretty elegant solution to the Scorpio battery positive post cable problem.
https://www.temu.com/2pcs-battery-termi ... 18830.html
Looks like a viable solution that's easier to implement than mine.brokencase wrote: ↑Thu Jun 22, 2023 9:36 am I saw these recently and thought they might be a pretty elegant solution to the Scorpio battery positive post cable problem.
Insufficient space for smaller gauge wiring.
- brokencase
I don't know if I agree Ed.
The big holes on it I believe could handle the Scorpio "big" wires along with one smaller wire in the same hole.
The remaining two small wires could go into the two small holes.
In my case the Scorpio did not have the original bracket. So I bought the Harborfreight battery disconnect.
https://www.harborfreight.com/battery-d ... 97853.html
In the hole on the opposite side I ran a bolt through and ganged all the ancillary cable eyelets together.
It has worked OK, but on a few occasions I have had to re-tighten the green knob. Seems to loosen over time. Which is why I am investigating alternatives.
- andyofcolumbusmerkur
Didn't we already have this debate about fitting something like this on the battery? Seems like it would work but only on certain types of batteries. I used something like it (not on a Merkur) in which the battery was flat across the top not including the top posts.
- brokencase
I mentioned one like this previously...
https://www.temu.com/1-pair-6-24v-tin-p ... 09070.html
But I like the other one better because it has the clear plastic cover.
I tried that connector years ago and eventually moved on from it although I can't recall the more than one reason why just now.brokencase wrote: ↑Fri Jun 23, 2023 2:42 am I don't know if I agree Ed.
Re the Temu one, 1 or more power wires for the Scorpio have quite short leads so that they don't easily reach around to the front top of the battery. They do reach okay to the side top of the battery...but it's unclear the Temu clamp will tighten if mounted sideways. Plus I wouldn't trust a non-lead battery clamp.
My version worked for all the Scorpios and years I had.
