Page 2 of 3
Posted: Thu Oct 18, 2007 11:52 pm
by MerlinMerkur
Frag wrote:Also the torque for the valve cover gasket is like really wimpy. I think it's somewhere in the teens.
You know when I took the VC back off for the 3rd time.. I noticed the screws were quite loose, at least one side of them were. I know I torqued the snot out of them when I put it on... seems like the gasket relaxed maybe and/or the rings squished.. something. You say teens.. in-lb or ft-lb.. I used a handy chart for fastener torq general and it said 3-4 ft-lb max, which isnt much at all.. my cheapo tor wrench doesnt even read that low reliably, so I wrist-guaged it. Still.. they loosened.
Posted: Fri Oct 19, 2007 6:44 am
by Chuck W
I've never "glued" the Ford gasket to the V/C and have never had an issue installing it.
With all the problems I've had on the Tbird engine this year...it's been off and on at least 10-12 times.
Posted: Fri Oct 19, 2007 3:16 pm
by bw_krupp
If you over torque the aluminum VC, the brass rings sink into the VC making the gasket un-reusable (and possibly the VC as well, since the brass rings will just sink in again next time), and also leading to leak. Hence why I like the stamped steel one better (and its lighter and looks better painted crinkle black as well).
Posted: Fri Oct 19, 2007 3:29 pm
by Chuck W
bw_krupp wrote:If you over torque the aluminum VC, the brass rings sink into the VC making the gasket un-reusable (and possibly the VC as well, since the brass rings will just sink in again next time), and also leading to leak. Hence why I like the stamped steel one better (and its lighter and looks better painted crinkle black as well).
Those silly insert rings aren't in the Ford gasket...only in the POS Fel-Pro one.....
Posted: Fri Oct 19, 2007 3:33 pm
by DPDISXR4Ti
Chuck W wrote:Those silly insert rings aren't in the Ford gasket...only in the POS Fel-Pro one.....
But Chuck, the Felpro one is blue - doesn't that count for something!?
Posted: Fri Oct 19, 2007 5:19 pm
by Chuck W
DPDISXR4Ti wrote:Chuck W wrote:Those silly insert rings aren't in the Ford gasket...only in the POS Fel-Pro one.....
Smurfs are blue too...and just as useless.
Ford Gasket
Posted: Fri Oct 19, 2007 5:28 pm
by MerlinMerkur
Here is the beauty in question... Cost me 38 bucks but... better than 8 crappy 16$ ones ehh.
Chuck W wrote:DPDISXR4Ti wrote:Chuck W wrote:Those silly insert rings aren't in the Ford gasket...only in the POS Fel-Pro one.....
I dont know, I hear they make good soup if you can catch them.
Extremely durable to install (OH and its not too long!!)
Another: Note the tabs that help keep it in place for install, yes please.
Posted: Thu Oct 25, 2007 3:53 pm
by XR4
i got a cork one from advance yeah i thought "this is cheap" but it fit perfect it might be only a one time use but hey for $8.25or what ever it was i thought it was worth it was i wrong?
Posted: Thu Oct 25, 2007 4:06 pm
by MerlinMerkur
yes lol cork sucks.
Never use cork if you can help it imo.
And no way you could reuse it. Ford one looks like it could go 10 times reused and beefy as a longhorn steak 8 for 1 use... 38 (FordOne) = 4.5 of those corks per cost but... many uses.
lol use what you want!
Posted: Thu Oct 25, 2007 7:33 pm
by Frag
I would use a cork gasket over that $#!%^& floppy rubber thing any day. Of course why not just used the Ford thing with the metal skeleton?
Posted: Sat Oct 27, 2007 11:01 am
by mikerobison
Not to throw too much into the mix....Victor valve cover gasket works perfect. I tried the blue Fel-Pro, and got the same results as you Travis, the Victor gasket fits like a glove.
Posted: Sun Oct 28, 2007 5:04 pm
by jkxr4ti
Mike, does the victor gasket have a metal frame like the ford unit does? Could you let us know where you purchased it?
Posted: Sun Oct 28, 2007 5:24 pm
by Frag
jkxr4ti wrote:Mike, does the victor gasket have a metal frame like the ford unit does? Could you let us know where you purchased it?
No.
Posted: Sun Oct 28, 2007 8:32 pm
by John Brennan
Then it sucks! There's no point in buying it! The Ranger gasket with the metal "skeleton" does not need glue, can be used over and over again, and turns everything else on the market into a piece of crap in comparison!
Any more questions?
Posted: Tue Mar 04, 2008 2:57 pm
by ianb
just install my ford valve cover gasket...install was a breeze so far so good. there was a crappy cork gasket in there before which was garbage IMO..leaked all over the place
