oil cooler gasket PN for the archives
There are three gaskets in the oil cooler/oil filter adaptor assembly. The dealer faxed me a copy of the parts fische, but I can't seem to figure out how to post images here. Here are the dealer PNs in case you are trying to track down these parts.
Block to oil cooler gasket: E3ZZ6L621A
Oil cooler to oil filter adaptor: E5RY6840A
O-ring under the bolt that secures oil filter adaptor to oil cooler: E5RY6838A
I got items 2 and 3 above for $5 and $3 a piece from Green Sales Inc (513-731-3304). Item 2 I had shipped in from a dealership in Georgia for $23.
Good luck stopping those leaks.
Jake
Jake
Jake
I have the proper oil cooler seal for sale that installs between the oil cooler & the block. I have listed this item on SVOCA, Turbo Ford, & 4eyed Pride. If you are interested in purchasing the seal let me know.
Qty:
1: $15ea
3: $14ea
5: $13ea
**All prices include S&H to The CONUS. Additional charges may apply for Canada or other areas outside The CONUS.
I will accept payments through paypal online.
If you would like pics of the o-ring let me know. You can also find several people on the other forums that have purchased the seals & have installed them. [/img]
Qty:
1: $15ea
3: $14ea
5: $13ea
Garret,Garret wrote:I already posted this but an old sealing ring from an oil filter works just fine or at least it has been for a year of DD action on my merkur
Best of luck with that. The oil filter gasket is not the same material & is not intended to go through the heat cycles & last. The design of the oil cooler o-ring that Modine used was meant to last 20+ years if it is left in place.
I have the proper seal if you would like to replace that oil filter gasket.
Mitch
I'm sure you do, but for 15 dollars, I think I can deal with replacing it should it start to leak again. Considering everytime I do an oil change I gather another spare.
Not knocking your product in any way, I'm just not fixing a 99 cent problem with a 15 dollar part that will probably outlast my car and I'm doing away with the oil cooler/heater unit anyways
As I said good luck with the oil filter gasket, it is your car & your choice. The proper seal will not leak when properly installed & will not become a potential problem.Garret wrote:I'm sure you do, but for 15 dollars, I think I can deal with replacing it should it start to leak again. Considering everytime I do an oil change I gather another spare.
Another thing to note, if you try to purchase the Ford NOS o-ring/seal it will run you at least $29.99 + shipping & handeling. The part I am selling is not the NOS Ford part but it is the equivilant replacement made to Modine specifications.
Mitch
You are dealing with one of the cheapest group of car folks around. Don't take offense and move on. I went to an air/air setup but may get a seal from you later on for another XR I own. I'd rather spend a few more bucks and not have to worry about leaks down the road. I find driving cars much more enjoyable than tinkering around with them.meotchh wrote:As I said good luck with the oil filter gasket, it is your car & your choice. The proper seal will not leak when properly installed & will not become a potential problem.Garret wrote:I'm sure you do, but for 15 dollars, I think I can deal with replacing it should it start to leak again. Considering everytime I do an oil change I gather another spare.
No offense taken, I'm just trying to get the word out that there is a proper solution for those that want it.Frag wrote:You are dealing with one of the cheapest group of car folks around. Don't take offense and move on. I went to an air/air setup but may get a seal from you later on for another XR I own. I'd rather spend a few more bucks and not have to worry about leaks down the road. I find driving cars much more enjoyable than tinkering around with them.meotchh wrote:As I said good luck with the oil filter gasket, it is your car & your choice. The proper seal will not leak when properly installed & will not become a potential problem.Garret wrote:I'm sure you do, but for 15 dollars, I think I can deal with replacing it should it start to leak again. Considering everytime I do an oil change I gather another spare.
Where are you located in Seattle? I'm in Graham & I also have some customers I serve in the Seattle area.
If you are not far & want to pick one up the price is $13 for local pick up.
Mitch
- Level 2
I'm actually just south of Seattle in Tukwila. I will keep that in mind when the time comes.meotchh wrote:No offense taken, I'm just trying to get the word out that there is a proper solution for those that want it.Frag wrote:You are dealing with one of the cheapest group of car folks around. Don't take offense and move on. I went to an air/air setup but may get a seal from you later on for another XR I own. I'd rather spend a few more bucks and not have to worry about leaks down the road. I find driving cars much more enjoyable than tinkering around with them.meotchh wrote: As I said good luck with the oil filter gasket, it is your car & your choice. The proper seal will not leak when properly installed & will not become a potential problem.
