Fender liners
Thanks for documenting this. The one I may try is the '93 - '97 VW Jetta - same donor as the front bumper several of us use. I'm thinking it will work well with the attachment points on the Jetta bumper as well as allow use of the little corner pans that attach to the lip spoiler.
We'll see - all just conjecture at this point.
mopman93
Post by mopman93 »
what did you use for the rear? 95 gt liners as well?
2.0 Duratec DD 45 DCOEs
aaul00
Post by aaul00 »
My rear liners are both in good condition and didn't need replacement. I can only speak for the fitment of the 95 Mustang liners up front.
-Andrew Aul
JimG
Post by JimG »
[quote="merkurmaniac"]On the fender liners, I DO think that they must make a difference sound wise. noise. ..........
I have no fender liners, and my car is loud on the highway. I have a really quiet exhaust too. I will be trying the fender liners.
[/quote]
The stock fender liners have some padding glued to the top of the arch - when i installed the Mustang liners I reinstalled it. To see pics of my installation checkout: http://merkursport.com/index.php?s=&sho ... t&p=332670
Jim Gosses
mhamilton
Re: Fender liners
Post by mhamilton »
From Facebook:
Ron Hofmann Sr. Here's what I got that works. 1995 FORD MUSTANG 5.8L V8 fronts for the fronts. 2003 FORD FOCUS 2.0L L4 DOHC fronts for the rears.
(This thread is older than Facebook.)
Re: Fender liners
As requested, some pics of my SN95 Mustang splash shields, as modified and installed in my right-front wheel well. The only two fasteners are the two screws you see using the factory screw locations. I had planned to use a zip-tie on the the spot behind the bumper wing (you can see the hole in pic #3), but I've found it stays in place just fine as-is.
