89 wouldnt acclerate
sic2706
Post by sic2706 » Tue Jun 29, 2010 4:01 pm
hello Merkur forum... I need some help
i have a 89 5spd merkur. It has been garage kept most of its life and clean but after sitting on the last few months the previous owner use to go out and start and and just let it run.. I went to go look at the car and it will start perfect idle perfect and even rev up smoothly. When you go to take off it boggs down ( acts like when a carburetor loads up) and wouldn't accelerate causing dentation after starting to boost.....I have been told possible ECU..Vac leak. etc etc whats your thoughts
thanks
sic
SARON81
Re: 89 wouldnt acclerate
Post by SARON81 » Tue Jun 29, 2010 4:05 pm
sic2706 wrote:hello Merkur forum... I need some help
thanks
sic
Any codes?
Start there.
sic2706
Post by sic2706 » Tue Jun 29, 2010 4:41 pm
Yeah, I am very unfamiliar with these cars i am a multi svo owner and decided to buy one these......so any detailed advice will help....Do these cars do the flash codes with check engine light or do i need a tool
Post by Ed Lijewski » Tue Jun 29, 2010 4:54 pm
Could be clogged injectors, dirty fuel filter, low fuel pressure, dirty primary wire connections at the coil, VAM door sticking, vacuum leak(s)...
YMMV 8)
Frag
Post by Frag » Tue Jun 29, 2010 5:57 pm
Check fuel pressure. Or simply swap regulators.
sic2706
Post by sic2706 » Tue Jun 29, 2010 8:22 pm
The previous owner said he checked the fuel pressure and it was 35 psi....dont know how true it is.... Its getting fuel but its like its not getting enough past idle
sic
Frag
Post by Frag » Tue Jun 29, 2010 10:33 pm
35psi when? At idle? With the vac line hooked up or not hooked up? Is pressure increasing 1:1? Hard data is better than what some random guy said.
sic2706
Post by sic2706 » Tue Jun 29, 2010 11:02 pm
OH i agree fully Frag... I just got the car and havent had time to do anything yet but figured i would ask the guys that knows these cars best. that maybe it might be a common merkur issue...
thanks for all the info i will keep you update
SIC
SARON81
Post by SARON81 » Wed Jun 30, 2010 8:42 am
You'll need a reader to pull codes.
No check engine lights.
86XR4Ti5SPD
Post by 86XR4Ti5SPD » Wed Jun 30, 2010 10:16 am
How old is the converter? Clogged maybe?
Ed, Nashville
Post by DPDISXR4Ti » Wed Jun 30, 2010 10:52 am
Could be lots of things, so start with Nick's advise and pull codes first.
