tire pressure question
velocityboy
Post by velocityboy » Tue Aug 17, 2010 11:02 am
This may seem like a silly question, but what the heck is the specified tire pressure for the XR? It has stock tires and rims. I looked on the door sticker- where one normally finds this info- but couldn't find anything on it abt psi.
--Patrick
89 Merkur XR4Ti (daily driver)
88 Chrysler Conquest TSi (currently out of commission thanks to anonymous s.o.b. hit and run)
78 Ford F-250 Ranger (propane conversion & all around cream puff)
Post by Ed Lijewski » Tue Aug 17, 2010 1:21 pm
33 lbs.
YMMV 8)
velocityboy
Post by velocityboy » Tue Aug 17, 2010 1:25 pm
Thanks!
--Patrick
alexob53
Re: tire pressure question
Post by alexob53 » Thu Oct 06, 2016 12:55 pm
Sorry to bring up an old post, but the factory sticker in my door jamb says 26 psi. I find this way too low and always inflate to around 33-35, however I just thought I would share this interesting information. I have an early 88 with 15" spatulas.
88 Merkur XR4Ti manual
90 Chrysler TC by Maserati 16V
00 Mazda MX-5 Miata LS 5-speed
01 Dodge Ram 2500 5.9 Cummins 5-speed
08 Smart Fortwo
08 BMW 135i Cabriolet
Post by my8950 » Thu Oct 06, 2016 3:04 pm
Look on the tire
Post by Ed Lijewski » Thu Oct 06, 2016 3:11 pm
^^ :headbang What does your tire say ...?
YMMV ;)
Post by John Brennan » Thu Oct 06, 2016 3:13 pm
Tire will give you the maximum, not what the manufacturer recommends for the car. If your '88 came with Spatulas, it's not a "Late '88." My first XR was a late-'88 I got brand-new, and it had mesh... basically, everything the '89's had except the cooling system revisions.
duncan1437
Post by duncan1437 » Fri Oct 07, 2016 1:26 pm
i've always kept mine at the factory spec...26 lbs...though it seems low compared to my other cars.
the mustang svo was 28 lbs front and rear
https://lmr.com/item/OS-DF1155/84-85-Mu ... sure-Decal
a bit puzzling....
Post by my8950 » Fri Oct 07, 2016 2:04 pm
Global warming, maybe the air isn't a dense as it used to be 30 yrs ago...
Post by John Brennan » Fri Oct 07, 2016 3:05 pm
It's a ride/performance compromise. Most modern tires are lower profile, and lower volume, so they have higher pressures. My Fiesta ST calls for 39 Front, 36 Rear, for 205/40 17 tires. Like Ed, I keep my 50-series tires on my XR at about 33 PSI for daily driving.
Choochoochoo
Post by Choochoochoo » Fri Oct 07, 2016 9:24 pm
Running a stock sized 15, I just go with 32 front and rear. It's an easy number to remember.
2008 Mercedes Benz R320CDI
1985 Merkur XR4Ti
alexob53
Post by alexob53 » Sat Oct 08, 2016 2:34 am
John Brennan wrote:Tire will give you the maximum, not what the manufacturer recommends for the car. If your '88 came with Spatulas, it's not a "Late '88." My first XR was a late-'88 I got brand-new, and it had mesh... basically, everything the '89's had except the cooling system revisions.
Yes, sorry I mean early 88! My bad!
08 Smart Fortwo
