Suspension question
Suspension question
hey just wondering if any one knows if you can use the fox body front struts????
Re: Suspension question
Piece of cake. Here's a link to the project plans... viewtopic.php?f=37&t=9364&hilit=appalachianmrunknown wrote:hey just wondering if any one knows if you can use the fox body front struts????
I've said it before, but i'll say it again just for the record:
"If you don't have a lot of money and you want a V8, get a mustang."
Mixing the corner carving, rally minded performance of an XR4 with one of the best known stoplight drag strip kings is like...well...they don't. Not without serious fabrication and money anyway. Apples to oranges to put it best.
Just one perspective.
-Neil
The Mechanic: You'd have yourself a real street-sweeper here if you put a little work into it (The GTO).
G.T.O. Driver: I go fast enough.
'55 Chevy Driver: You can never go fast enough.
-Two Lane Blacktop
-Two Lane Blacktop
If your looking for a set of struts for your XR and are looking into a different option, the 1999 to 2002 Ford focus struts fit, look into it.mrunknown wrote:hey just wondering if any one knows if you can use the fox body front struts????
Ben
You do need to modify the top hats though.
That should allow 1999-2005 struts to work. Late in 06 they changed.
Oddly, Ford thought differently, and placed that very motor in certain models of the Sierra... no swap is "easy," but it is among the easier swaps, and many have done it and have been very happy with the results.Swagman00 wrote:I've said it before, but i'll say it again just for the record:
DG was making some taper spacer(for lower ball joint) to mount the mustang spindle to the XR. don't know if he ever finished
Former CMC and current American Iron class drivers might argue that a mustang can be made to handle at least decently.Swagman00 wrote:I've said it before, but i'll say it again just for the record:
"More horsepower makes you faster in the straights. Less weight makes you faster everywhere."
-Colin Chapman
-Colin Chapman
Care to elaborate (with links)?DSPXR4ti wrote: If your looking for a set of struts for your XR and are looking into a different option, the 1999 to 2002 Ford focus struts fit, look into it.
Ben
-Colin Chapman
-Colin Chapman
thx for the info as my car is in need for new suspension you guys can check out my car and its current state over in the project and photo section, oh and do the back shocks and springs fit as well or no go on that????
Might want to check out this thread:
http://forum.merkurclub.net/forum/viewt ... a6b18580a2
And on the rear look at MC2 racing or some nascar Front springs for use in the rear of the XR these are the right diameter and you can choose from a variety of rates. Also do a search for explorer rear shocks, some have used these on the rear of the XR. Some of the circle track shocks are pretty close dimensionally to the XR rear shocks also.
so nascar rear springs it will be as both of mine are broken and i was thinking of getting these shocks http://www.speedwaymotors.com/AFCO-12-S ... 24042.html also was wondering if someone could recommend some spring rates, i want to do some auto crossing and hopefully some drifting any info would be great as i'm baffled with what to do, gotta keep in mind i'm a builder on a budget
- pyropete125
Koni yellow adjustable struts and shocks are available... I am a koni dealer and can get you a great deal on them if your interested.
pete
pete
i may be interested depending on the deal you can get me, pm me
Can you give a ballpark estimate for a set?pyropete125 wrote:Koni yellow adjustable struts and shocks are available... I am a koni dealer and can get you a great deal on them if your interested.
pete
