no crank no start. *fixed.. starter*
Razorthirty
Post by Razorthirty »
Hi this is gonna be short cause im late for work now.. >.> I went our start my car up this morning, around 15-20 degrees out, i turn the key and hear a loud click, (starter solenoid?) but no crank, i hook up a 110 amp jumper (to a tested good battery mind you) and it starts after holding the key 'start' for about 2 seconds suddely turns and starts norma;y... help?
'85 XR4Ti super sunfaded blue Stock except for the turbo. 10psi, 5spd
Ben
Re: no crank no start.
Sure; first suspect would be he solenoid. ~ $20 from any parts store.
YMMV 8)
richardcurtis
Post by richardcurtis »
clean the battery terminals and cable clamps. Then re-try before buying a new solenoid.
Richard Curtis
admiralbrown
Post by admiralbrown »
I agree with richardcurtis it sound like a loose battery terminal that has oxidized. I bet one of the connections is loose enough to turn. On a cold day the metal shrinks making the contact area smaller and on a cold day you battery produces less power.
1987 RS500 clone courtesy of the little blonde Merkur fairies of Minnesota
2000 Z3 most dependable, least practical car I could find
2009 Jetta Sportwagen TDI 44 mpg
2012 Ford Focus SEL 5-door, the wife's car and the only automatic
Razorthirty
admiralbrown wrote:I agree with richardcurtis it sound like a loose battery terminal that has oxidized. I bet one of the connections is loose enough to turn. On a cold day the metal shrinks making the contact area smaller and on a cold day you battery produces less power.
Nope, terminals are both clean and tight and steel, not crappy lead deals. the line to the solenoid is good and so is the line to the starter, check with a test light when i hit the key the test light lit on the starter side. So we figured its the starter itself and i went and picked one up today, gonna install tomorrow morning.
Btw my day job is a mechanic, though i only started like 3 months ago >.> learnin fast.
Ben
You can always bridge the teminals on the solenoid with a screwdriver to bypass it to determine if it is the solenoid or the starter itself.
adamt85
Post by adamt85 »
where did you hook the jumper box too? the batt or solenoid? if the battery then it is more than likely your battery.
89 5spd white xr4ti-wrecked
88 white cosified xr4ti
Test light lit doesn't mean starter will/can get the huge amperage flow it needs. Solenoid's internal contacts build up deposits until current can't flow. Solenoid failure at some point is typical. Whether that's the current problem or not, replacement now us cheap and good future insurance against being stranded unexpectedly. Also, do a voltage drop test on the negative battery cable.
YMMV ;)
Razorthirty
new starter fixed the issue, i may still replace the solenoid though, we'll see.
Ben
