neg. rear camber with all stock parts.
rab
Post by rab » Wed Mar 14, 2012 1:03 pm
im very new to the merkur, but i bought 2 last year and im thinking im going to start
mess with the good one, one was for parts only a roll over.
well looking at them they both appear to have a good amount of neg camber in the rear.
do these car come with that way, or is it just worn out parts, or what?????
im guess both cars have oe/stock parts still on them as they both are under 80,000 miles and unmolested.
xR4rally
Re: neg. rear camber with all stock parts.
Post by xR4rally » Wed Mar 14, 2012 8:08 pm
Due to the design of the semi-trailing arm rear suspension, as it sags the top of the wheel pulls inward. You most likely have worn or sagging bushings, springs, or both. This is a common problem with these cars.
There is plenty of info on this forum about it and some fixes. Also check with the encyclopedia and there may also be some info on the mc2 website.
"More horsepower makes you faster in the straights. Less weight makes you faster everywhere."
-Colin Chapman
Post by hEaT » Wed Mar 14, 2012 8:53 pm
I'd bet money on the diff mount being a major cause of that as well.
Post by Esteban » Thu Mar 15, 2012 1:18 am
Yeah you can blame it on 20+ year old rubber bushings. A visit to MC2racing.com can help fix these. But the cheapest way would just be to shim the carriers to correct the camber and toe.
rab
Post by rab » Thu Mar 15, 2012 12:43 pm
anyone know the exact bushings that usually cause this?
im sure i will change them all with poly or better along
with the springs and shocks.
Post by Esteban » Thu Mar 15, 2012 1:21 pm
The rear diff mount is the main one. As well as sagged springs
blizboy
Post by blizboy » Thu Mar 15, 2012 4:32 pm
I'm at a loss as to how the rear diff mount being bad can cause negative camber problems........
Sagging springs is the most obvious or short aftermarket springs.
John
Post by Esteban » Thu Mar 15, 2012 7:39 pm
The rear beam is connected to the chassis via the beam mount bushings and the rear diff mount. If the rear-most connection (diff mount) is bad/sagged, then that effectively moves the beam closer to the chassis allowing the springs to compress more, acting as if they are sagged. or at least that's how i understand it simply.
noslack2mack
Post by noslack2mack » Thu Mar 22, 2012 11:24 pm
Yeah, right on. It's a funky she-devil under the rear-ness of one of these. I'm now up to four of them and I've been transplanting one diff to another this week. Weeeeiiiird rear end. It's like a freaking Mercedes or something. Never seen one quite like it. When you undo the rear body mount on the diff, the whole thing swings down like a ramp...or better yet a DRAWBRIDGE and hands you the rear end. Like, "here's the chunk you ordered, Sir". Damn polite Europeans and their swingarms.
Ronald Reagan was the best thing that ever happened to this country.
-Mike
rab
Post by rab » Fri Mar 01, 2013 9:42 pm
Post by Esteban » Sat Mar 02, 2013 3:03 am
The one you want is the rear diff mount (first link). They are currently sold out but are working on a newer version which should be available real soon.
Post by Ed Lijewski » Sat Mar 02, 2013 9:31 am
Many of us would be fully satisfied with the "old" version [^^] if it were still available... Any new diff mount is better than a used/failed diff mount. :P
YMMV 8)
Post by anglin » Mon Mar 04, 2013 10:01 pm
Ed Lijewski wrote:Many of us would be fully satisfied with the "old" version [^^] if it were still available...
Well, it might make you feel better to know that the new version is like the old version, except it's new. And different.
If you want a hint at how similar/different they are, this video provides a hint or two: http://youtu.be/fPMeAkXklo8
DSPXR4ti
Post by DSPXR4ti » Mon Mar 04, 2013 10:42 pm
So with that Vid. I couldn't hear what your making?
Ben
Post by Ed Lijewski » Tue Mar 05, 2013 10:47 am
Veddy interesting! (Now I've got negative camber of my eyes looking fruitlessly for that "hint". :-)
I'm assuming the new diff mount was in a rear corner of your workbench in the early frames of the video, right? :-/ :-D
J/K
