Your right the intake is not helping, but I didn't have later style turbo lower intake. So I used what I had.
I'm just above 200 cfm on the intake so I give you a few more test readings I did for comparison.
Intakes
Ported upper 1984 SVO average port flow - 207 cfm 828cfm total
Ported lower 1984 SVO average port flow - 219 cfm 877cfm total
Early tall gutted turbo upper 926 cfm
Square pattern Turbo lower - Untested
Short stock upper - 696cfm
N/A lower - Untested
Throttle Body
Stock 45mm - Untested
50mm Ford 5.0L 523cfm
65mm Ford SVO 538cfm
70mm BBK 726cfm
75mm Accufab 916cfm
Exhaust manifolds/header
I am unable to locate my notes on this but the average port flow on a ported E6 is 218cfm and the ATR header is just a hair better at 220cfm. Compared to a stock e6 at around 200cfm. Bobs log manifold did very well although port 3 was a little low. It took about 5 minutes to fix with a little grinding. Bobs was 213cfm out of the box and 215cfm after fixing port 3. The china made header from E-bay was only little better then stock around 205cfm. I did not do any testing on Boport headers but Boport headers are around 238cfm according to the Turbo ford forums and I didn't test any center mount turbo headers. All the manifold/headers I tested flowed better then the iron heads so any manifold should work.
I'll try a .84 housing and see what it does.
whitelx wrote:What is your plan for this engine? It seems like you have spent a ton of time on the engine dyno with several different combinations, but never put one in a car. I'm just curious. I'd love to be able to spend a ton of time on an engine dyno testing out different combos, but unfortunately I don't have that luxury. Impressive flow from that head BTW.
I want to do a run at the Silver State 100. I did this once before with a 1989 Dodge Daytona Shelby turbo back in the early 90's and once with my 1985 1/2 Viper Red SVO Mustang. It should be fun to see what the XR4ti can do. Most of the time it will just eat up rice burners on the street and maybe some really quick trips across town for some ice cream at the local Dairy Queen.
Two of my engine combinations did make it into cars. My Viper Red SVO has build #2. Build #2 was a 2.5L with the t3/4 hybrid turbocharger 328rwhp. Build #3 made it into the White SVO. Build #3 is a 2.8L tall deck motorsport block with a GT35 turbrocharger 385rwhp and 442hp at the crank.
Before anyone asks what happened to build #1. Build #1 was installed into the metal scrap dumpster. It made too much hp for it's stock tiny rods and way too much boost on the standard turbo for the standard pistons. I'm sure it was making 800hp+ when the stock wastegate failed and boost climbed to over 50psi (just a guess because my boost gauge was not working). All I heard was ping ping Ping Ping!! Ping!!! PING!!! Bang!!!! Boom!!!!!!! ....... Sizzle..... Pisssssss....... Clunk Clunk Clunk...... BOOM!!!!!!
I get to spend a lot of time on the dyno and flowbench. I usually trade parts/labor and engines for engine dyno time. The flowbench I can use anytime I want. After I get it close on the engine dyno I chassis dyno it with the engine installed. The cost is around $400 for a 1/2 day. I just hate losing so much power with a bad tune.
The head took a long time to get it to flow that good. The head probably has a few extra miles on it from me carrying it from where I grind on it to the flowbench and back and forth. It took about 5 weeks to port the head working on it 1-2 hours a day. The hardest thing about it was the combustion chamber. Since I started with a N/A head the combustion chamber started at 54cc and I reworked it to 60cc, but getting each port and combustion chambers exactly the same took an incredible amount of time. I think the next time I do this I'm going to get a shiny new aluminum head just because it would be a lot lighter to carry around.
I don't have anything that compares to Schneider spec'd out cam in any of my notes. I do like cams with a larger lobe center and prefer ones in the 116-118 range. It should be a good cam compared to your current cam. I also like cams with a larger exhaust duration compared to the the intake duration, because the intake ports can be made to outflow the exhaust. Since you will be turning 7000rpm what are you looking at making for power?
James
