aftermarket turbo?
Re: aftermarket turbo?
Post by hEaT »
That's the stock turbo. All XR turbos were water-cooled.
http://www.merkurencyclopedia.com/Motor/turbo.html
DirtyMerk85
aftermarket turbo?
Post by DirtyMerk85 »
Its my understanding that the xr's only came with oil cooled turbos..no coolant line going to them..is that correct?
My turbo has a coolant line going into and a return line as well..also says "ar .60" on it..
Could this be a turbo from an svo or a turbocoupe?
-Matt
Got Boost?
1985 XR4TI
Nimbus Gray
T5 transmission, cone filter, MBC (16 psi)
thebronze
Post by thebronze »
XR's came from the factory with WATER COOLED Turbos.... Some have removed the cooling lines(I have no idea why)
Kevin
-John Wayne
Post by hEaT »
thebronze wrote: Some have removed the cooling lines(I have no idea why)
Simplification of the cooling system, but I wouldn't recommend it on a stock car or daily driver.
DirtyMerk85 wrote:Its my understanding that the xr's only came with oil cooled turbos..no coolant line going to them..is that correct?
As stated, all XR's came with water-cooled T3 turbos. It sounds like you have a stock turbo, probably the original.
Only the early Turbo Coupes came with oil-only cooled T3 turbos.
