forge bov question
ford nutz
forge bov question
Post by ford nutz » Sun Mar 31, 2013 8:39 pm
hello another question , does anyone know what the pressure is I need to use, to test to see if my bov is leaking. I heard if I use too much pressure i can rip the diaphragm, and not enough pressure welll.. just wont be enough to tell you . I looked under the website and cannot find anything that says how to test it either, so if someone knows pls inform me, thank you.
turboplz
Re: forge bov question
Post by turboplz » Sun Mar 31, 2013 10:05 pm
Do you have a true forge or one of the knock offs? I had a knock off once that the plastic lower diaphragm wouldn't seat correctly once in a while. IIRC, I lightly sanded down the edges and then greased the edges with bearing grease and never had an issue again.
Jason
2014 Focus ST
Post by Esteban » Sun Mar 31, 2013 10:31 pm
When I do a boost leak test on my car, i toss in 20psi. The real forge bov should be able to handle 30psi with the proper spring. There is no diaphram, just 2 o-rings.
ford nutz
Post by ford nutz » Mon Apr 01, 2013 6:37 am
Yes I do have a true forge bov it wasn't cheep and i did buy the spring kit as well both from mc2 racing
aviatorpa23
Post by aviatorpa23 » Mon Apr 01, 2013 5:42 pm
Clean it - grease - renew the o-rings from time to time and it will serve you well. It will hold what a T3 or T4/T3 combo will toss at it, within the confines of optimum waste-gate setting for the turbo
Jim D.
Retired and Accepting it!
turboplz
Post by turboplz » Mon Apr 01, 2013 8:22 pm
Esteban wrote: There is no diaphram, just 2 o-rings.
I couldn't come up with the correct word for that piece, plug, stopper, whatchamacallit...so I used diaphragm, lol.
But as far as testing it, if you're going to pressurize the intake to check for leaks, it is good practice to remove the followers from the intake lobes. This will help to assure you don't lose any pressure out the exhaust.
You can also try rigging something up with pvc and some clamps to only test the bov.
Jason
2014 Focus ST
Post by Esteban » Mon Apr 01, 2013 8:54 pm
They are actually referred to as pistons. Lol
turboplz
Post by turboplz » Mon Apr 01, 2013 9:40 pm
Dammit, see....and I KNEW that too. Getting old sucks! :thumbsdn
Jason
2014 Focus ST
