Turn indicator again
Anyone ever heard of a way to put in a different turn signal switch, than the stock one? I keep reading how the stock ones always fail no matter what.
Re: Turn indicator again
I've never had one fail on any of the three XRs that I've owned over 20+ years.MissErika wrote:Anyone ever heard of a way to put in a different turn signal switch, than the stock one? I keep reading how the stock ones always fail no matter what.
All I know is that I found another forum where people complained about having to replace it numerous times.
Don't worry about it
Only reason I ask, is mine did fail, and I dont want to et a used one and have it fail too.
I got a Euro-style one from Jeff, and like it a lot, especially the hazard switch. I think it's made better-- certainly feels like it-- plus it's newer.
Um, Miss Erika: You shouldn't be reading any place but here.
I think it all depends upon how you activate your turn signal. If you slam it down, then yea, they'll break. The mini-vans my wife drives have both broken turn signal switches, both for the left turn. I doubt we make more left turns than right, but it is a lot easier to put a lot more pressure on the switch when turning left.MissErika wrote:All I know is that I found another forum where people complained about having to replace it numerous times.
I just try to remember these switches are about 25 years old for the newest ones, so they will break. I use them with a soft touch.
The only issues I have had with the turn indicator switch-other than the hazard issue, that is-is the failure of the cancel cam.
Some days, it's just not worth chewing through the restraints.
1988 Crystal Blue XR4Ti
The Euro style is the way to go, the hazard button is much sturdier and the unit is a direct replacement!
Jim Gosses
But for the purists, there is a noticeable difference. The Euro one has a much more rounded look to it, so unless you're replacing both switches, you can see something's a bit off, but you might not be able to tell what it is.JimG wrote:The Euro style is the way to go, the hazard button is much sturdier and the unit is a direct replacement!
- KhanTyranitar
- Level 3
I'm not a purist, I'll go for a Euro one when I need it.
1986 Merkur XR4Ti
Work in progress
1986 Merkur XR4Ti
Work in progress
- merkurdriver
Definately.JimG wrote:The Euro style is the way to go, the hazard button is much sturdier and the unit is a direct replacement!
Have the "upgraded" euro ones in stock and on hand...as well as brand new stock ones and good used stock ones.
