Clutch pedal bushings???
nzwinrz
Post by nzwinrz » Sat Sep 28, 2013 10:00 pm
Couldn't find another thread about this, but are there replacement bushing available for the clutch pedal?
In XS 7
Re: Clutch pedal bushings???
Post by In XS 7 » Sat Sep 28, 2013 11:56 pm
Maybe blugg have them, not sure but ask him, he got a lot of parts, even many not listed on the web page so give him a call or send an e-mail, here is the web site (but is better if you call or e-mail):
http://www.merkurmidwest.com/index.html
:cheers
Rob'Z
Post by Rob'Z » Mon Sep 30, 2013 9:19 am
If not already available through a vendor I can machine a run of them out of aluminum or Delrin.
Power is nothing without control.
Post by DPDISXR4Ti » Mon Sep 30, 2013 10:06 am
nzwinrz wrote:are there replacement bushing available for the clutch pedal?
To the best of my knowledge, no, these are not available from anyone. I can't recall ever seeing it available as a factory part. I like the idea of someone producing them in delrin or other suitable material. :thumb
nzwinrz
Post by nzwinrz » Mon Sep 30, 2013 10:09 am
I had been pondering the same thing, to get my machinist to do some. Have you got a good one to work from, or pedal assembly? How much do you think it would cost?
Glenn
Rob'Z wrote:If not already available through a vendor I can machine a run of them out of aluminum or Delrin.
nzwinrz
Post by nzwinrz » Mon Sep 30, 2013 10:31 am
I'm having the Ford dealer send over some for a '89 Fox body, to compare, possibly the same. Keep ya posted..
UPDATE no beano...to thin and longer..
I did find them with quadrant from OPMD
Rob'Z
Post by Rob'Z » Mon Sep 30, 2013 6:28 pm
I have a 5-speed XR but haven't pulled it apart before. If someone can get me accurate measurements of a good stock piece(s) I can make some. Guessing $15-20 shipped for a pair.
Rob
nzwinrz
Post by nzwinrz » Mon Sep 30, 2013 9:08 pm
I took the two out of my auto brake pedal, they appear good, lot tighter than the 5speed, same ones. I'll get my calipers and measure them, and the shaft & pedal
Rob'Z
Post by Rob'Z » Mon Sep 30, 2013 11:18 pm
A diagram or some pictures showing their orientation would be great as well.
Rob
nzwinrz
Post by nzwinrz » Mon Sep 30, 2013 11:49 pm
Got this with my home unit, can get decimal reading once I go back to work tomorrow
Shaft diameter..
Outer Diameter..
Inner Diameter..
Shoulder Thickness..
Total thickness..
Locating tab..Could probably do without
nzwinrz
Post by nzwinrz » Tue Oct 01, 2013 12:10 am
How bout I send you, a pedal(my old brake), shaft, mount and 2 bushings. You can use for development.
Once you have, how long to make?
Rob'Z
Post by Rob'Z » Tue Oct 01, 2013 12:56 am
Without the tab I can EASILY make thos in the CNC lathe. With the tab I'm probably not interested in making them.
PM me for shipping address if you want to send parts, probably not necessary with the more accurate dimensions.
Rob
nzwinrz
Post by nzwinrz » Tue Oct 01, 2013 8:24 am
I don't believe the tab is necessary, I don't see the need to hold them from rotating.
Could they be done in Brass?
Post by DPDISXR4Ti » Tue Oct 01, 2013 10:15 am
nzwinrz wrote:I don't believe the tab is necessary, I don't see the need to hold them from rotating.
That was my thought as well. And machined as a "minor" interference fit, it shouldn't rotate any way.
nzwinrz
Post by nzwinrz » Tue Oct 01, 2013 10:16 am
The 2 most critical points are the shaft od is .6275 and id of pedal arm .745
I measured the nylon bushing installed, does compress some from pics. ID tightens to .632-.634
