I'll also give Mike a shout-out that these are quality units. I have 3 of them. No such problem as heat-soak. Think about it guys, the only time you would have heatsoak is if the engine is shut off and the air in the intercooler is stagnant. When it's running, even parked, air rushing through the inside of the intercooler will never let is raise more than a degree or 2.Heat rises, so it will heatsoak a little while sitting still but once your moving and have a Cossie grille that will be long dissipaited
This new version we put a small air gap between the rad and IC - you could sneak some rubber in there or a phelonic plate as an additional barrier.
Merkur Depot Radiator and Intercooler Install (Lots of pics)
Re: Merkur Depot Radiator and Intercooler Install (Lots of p
XR and Scorpio blower motor rebuilding, LED upgrades, XR lock service
Ah, I noticed that. I haven't committed to one of your rad/IC's yet, but I was thinking about what I could squeeze in there when I do.merkurdriver wrote:This new version we put a small air gap between the rad and IC - you could sneak some rubber in there or a phelonic plate as an additional barrier.
- 86XR4Ti5SPD
- Level 3
I sandwiched a rectangular section of foil insulator between my IC and the shorty rad. It has stayed in place nicely, and I assume it is beneficial.
Ed, Nashville
Any pics of the final install?? Curious how you did the cold side of the intercooler to the intake without a 45° piece
WE NEED AN UPDATE!!! I want to see the final results of this installation. I was interested in theese parts but i need a more complete write up of required parts and fitment before i commit to buying itotis147 wrote:Any pics of the final install?? Curious how you did the cold side of the intercooler to the intake without a 45° piece
99 Subaru Legacy gt wagon
69 VW bug
88 Merkur Xr4ti
Meow
69 VW bug
88 Merkur Xr4ti
Meow
Here's my final install. I got a boost leak somewhere I need to track down. I literally bought piece for piece what he bought in his first post, aside from the radiator fan, which I had one laying around from a past... project (that never got started).Skibob6 wrote:WE NEED AN UPDATE!!! I want to see the final results of this installation. I was interested in theese parts but i need a more complete write up of required parts and fitment before i commit to buying itotis147 wrote:Any pics of the final install?? Curious how you did the cold side of the intercooler to the intake without a 45° piece
https://www.dropbox.com/s/jwgaod4cdlg9e ... 191425.jpg
otis147 wrote:Here's my final install. I got a boost leak somewhere I need to track down. I literally bought piece for piece what he bought in his first post, aside from the radiator fan, which I had one laying around from a past... project (that never got started).Skibob6 wrote:WE NEED AN UPDATE!!! I want to see the final results of this installation. I was interested in theese parts but i need a more complete write up of required parts and fitment before i commit to buying itotis147 wrote:Any pics of the final install?? Curious how you did the cold side of the intercooler to the intake without a 45° piece
Thanks otis. Still havent decided if i want this front mount...
69 VW bug
88 Merkur Xr4ti
Meow
69 VW bug
88 Merkur Xr4ti
Meow
Ya thanks for the pic, Otis. That's exactly what I want to do. I have my cossie shorty in & IC. but the IC not hooked up yet.
Ron
1968 Dodge Charger 383
Was the easiest install I've ever done for anything on this cursed car. I removed my AC condenser while I was there, but it can still be kept if you want to keep your AC. Hardest part was trying to use a jack and 2x4 to balance the radiator while I bolted it up there myself. I ended up having to use a spacer on the top side of the radiator flange where it bolts up; if I bolted it up right, my hood would not shut for some reasonSkibob6 wrote: Thanks otis. Still havent decided if i want this front mount...
The best part of this setup is being able to keep your A/C.otis147 wrote:Was the easiest install I've ever done for anything on this cursed car. I removed my AC condenser while I was there, but it can still be kept if you want to keep your AC. Hardest part was trying to use a jack and 2x4 to balance the radiator while I bolted it up there myself. I ended up having to use a spacer on the top side of the radiator flange where it bolts up; if I bolted it up right, my hood would not shut for some reasonSkibob6 wrote: Thanks otis. Still havent decided if i want this front mount...
Or maybe it is because it is 1/10th the cost of Dave Planakis radiator/inter-cooler combo.
- KhanTyranitar
- Level 3
I am definitely going this route when I finally am able to continue working on my XR. Hopefully towards the end of this summer.
1986 Merkur XR4Ti
Work in progress
1986 Merkur XR4Ti
Work in progress
For some reason, I cannot edit my last post. But I moved some images around in my dropbox folder and that link no longer works. Here is the updated link, along with an imgur link for archival purposes.
https://www.dropbox.com/s/jzsgolgopmdvu ... 5.jpg?dl=0
http://imgur.com/ZzD8WVQ
Any chance anyone still has the pictures? I cant see any.
'88 Merkur XR4Ti-The Build
'87 Merkur XR4Ti-The Beauty
Yeah, I wish there was a place that could store the pictures other than links on a thread. There are or have been many photo references taken and then lost.Chris_12 wrote:Any chance anyone still has the pictures? I cant see any.
Mike has some pix on his site, which is where you're gonna go to to order it, anyway:my8950 wrote:Yeah, I wish there was a place that could store the pictures other than links on a thread. There are or have been many photo references taken and then lost.Chris_12 wrote:Any chance anyone still has the pictures? I cant see any.
http://www.merkur.50megs.com/photo2_1.html
Also, an excellent source for stored pix is on Picture Pages at Merkur Tech:
http://www.merkurtech.com/merkurtech/pi ... s/main.php
Sort by "Intercoolers," and I believe Mike's is the first one featured (along with many others). Merkur Tech is an absolute gem, and, I believe, underutilized and -appreciated.
Enjoy.
