Replacing differential seals.
hmarkan
Re: Replacing differential seals.
Post by hmarkan » Sun Jul 12, 2015 10:48 pm
C-clip
Old seal removed, new one in
axle seal before removal
Differential (top right) and T-9 seals ordered from Ebay UK
Overhauled and back on the car now
Murat in NJ
1989 XR4ti 5 spd, maroon
In XS 7
Post by In XS 7 » Sun Jul 12, 2015 10:52 pm
Looks very nice, Great job. :cheers
mhamilton
Post by mhamilton » Mon Jul 13, 2015 12:11 pm
Does this look like the same one?
http://www.ebay.com/itm/111343336861?_t ... EBIDX%3AIT
BTW, I called BAT, seals out of stock. O rings, one left
Rapido, $28+ for each seal, $14 for an O ring.
hmarkan
Post by hmarkan » Mon Jul 13, 2015 2:02 pm
Hi there,
That does look like the same one, but seems like they changed the differential seal a bit. Even the seller I got mine from changed the pinion seal, but the description suggests they will fit our XR's. Here is the link to what I purchased, I was happy with the seller, shipping, etc.;you may go to link, contact the seller with questions.
http://www.ebay.co.uk/itm/FORD-SIERRA-C ... 1241wt_785
Also, I had found this site during my previous searches, as another source, if I had to; but not sure if they ship to US.
http://www.bearingkits.co.uk/SIERRA-&-E ... IT/116.htm
Finally, RockAuto may have them.
Good luck
Murat in NJ
hmarkan
Post by hmarkan » Mon Jul 13, 2015 2:10 pm
I forgot to mention, you must be talking about the O-rings on the locking plates on each side.
As per Grayson's message, I did not remove those since I didn't have any issues with bearings and simply wanted to replace the seals only to stop the leaks. The second link above has a nice blow up drawing showing all the parts in detail, when you click on the part.
Good luck!
Murat in NJ
