Merkur Depot shorty rad fan setups
Post by milehighXR » Sat May 09, 2015 4:28 pm
I wanna see pics(sent direct to me, or links to them) of what folks are doing for radiator fans for Merkur depot shorty rads. These only come with one flange at the bottom of the rad(at least mine did), and I have a Cossie 2wd IC mounted above my rad, but the fan setup I had previously I don't think will work, unless I have someone weld a flange on the top of the rad for me. So lets see those pics.
Matt01
Re: Merkur Depot shorty rad fan setups
Post by Matt01 » Sat May 09, 2015 6:15 pm
like everyone:
lowered86
Post by lowered86 » Sat May 09, 2015 11:01 pm
Single fan from Siliconeintakes.com. Attached it with included plastic fasteners. It has been on my daughter's car almost 3 years without issue.
Post by Esteban » Sun May 10, 2015 12:55 am
At the bottom, I used nuts and bolts. At the top, i used the zip ties they provide. Can send you a photo if you pm me your number.
85xr
Post by 85xr » Sun May 10, 2015 6:57 am
So, is a shroud not needed with the shorty? :econfused
greg
timandsam
Post by timandsam » Sun May 10, 2015 2:04 pm
85xr wrote:So, is a shroud not needed with the shorty? :econfused
Looks like lots are running without one (including myself) but i thought this was a good idea: viewtopic.php?f=30&t=28838&start=0#p264699
He used a shroud for a Miata. Pretty inventive.
Mono Silver 85 XR4Ti: Ported Head| Ported Intakes|Schneider Roller Cam|Big NPR IC|3” Exhaust|Ported E6|Walbro 255|PiMP|80lb injectors|HE341|Alkycontrol|T5Z
Post by Esteban » Mon May 11, 2015 2:33 am
If you use 2 12" fans, then there isnt much surface area left uncovered. You'll be fine.
Post by John Brennan » Mon May 11, 2015 9:44 am
Here's my setup. Shorty has been moved to the top to allow the use of the stock '89 upper hose, make space for the IC at the bottom:
Matt01
Post by Matt01 » Mon May 11, 2015 9:59 am
John Brennan wrote:Here's my setup. Shorty has been moved to the top to allow the use of the stock '89 upper hose, make space for the IC at the bottom:
in my setup the stock 89 hose works fine with the rad lower too.
Post by John Brennan » Mon May 11, 2015 11:14 am
It was stretching a bit with mine, plus I like having the vent hose at or near the highest point on the engine side. This also gave a lot more room for the Porsche 944T IC I was planning on installing at the time, or any number of other aftermarket IC's.
Post by Ed Lijewski » Mon May 11, 2015 11:23 am
Darn near direct routing for radiator fan air to VAM.
YMMV 8)
Post by John Brennan » Mon May 11, 2015 11:53 am
Pic is older, there was a project (turbo replacement) underway at the time it was taken; VAM/filter were wired up and out of the way (red wire). Filter resides next to holes for stock airbox setup, barrier separates it from engine compartment air. So don't worry, the kids are alright.
Post by Ed Lijewski » Mon May 11, 2015 12:27 pm
So, caption "old" photo(s) thatly ^^^.
YMMV 8)
Post by John Brennan » Mon May 11, 2015 12:46 pm
Gosh darn it, I'm so sorry I forgot that, I'll try to do next time better, Sir. :notworthy
By the way, are you still "cooling" your TCIC from bottom to top and "venting" the air out from that credit-card-sized slot on the back corner of the hood?
Post by Ed Lijewski » Mon May 11, 2015 2:38 pm
Giovanni Battista Venturi, for my channeling him, smiled at me, "whilst" he waggled his finger at thee, Venturi Effect denier. :sawzall :poke :puke :mrgreen:
YMMV 8)
