89 xr4ti
David10259
89 xr4ti
Post by David10259 » Mon Nov 02, 2015 9:31 pm
I'm about to pick up a 89 xr4ti with 60000 on it I was planning on lowering and getting a nice set of wheels and tires for it but I can't seem to find any parts for it from well known brands so I was told its on the f platform like the foxbodies so I was wondering if anyone knew if those suspension parts fit on the xr4ti or not?
Re: 89 xr4ti
Post by John Brennan » Mon Nov 02, 2015 9:51 pm
Hi David, Welcome Aboard, good to have you with us. 8)
The short answer is "no," although some Fox body cars have 4 x 108 wheel bolt patterns, and some fit Pony or other wheels with this pattern, the offsets tend to the small side, pushing the wheels out farther than is ideal. As for other suspension parts... no, you need to look at parts designed for these cars or their European brethren. My best avice is to curl up with this and other Merkur informational sites, such as the Merkur Encyclopedia, and Merkurtech.com. All of these can be found at www.merkurdesktop.com.
Then, of course, ask away! :cheers
Matt01
Re: 89 xr4ti
Post by Matt01 » Mon Nov 02, 2015 11:40 pm
literally almost nothing in common no.
mhamilton
Re: 89 xr4ti
Post by mhamilton » Wed Nov 04, 2015 9:00 pm
A common wheel you can use is ones from the Ford Contour.
"Head for the Hills, the Town of Lompach is Under Water!"
Re: 89 xr4ti
Post by merkurdriver » Thu Nov 05, 2015 12:52 am
Fox body 4 lug mustang wheels fit..but that's about it. Suspension stuff is not interchangeable.
hbar
Re: 89 xr4ti
Post by hbar » Sat Nov 24, 2018 6:36 pm
Thought I'd resurrect this thread because my question relates to the OP.
I have a set of 16" x 7.5 wheels from an 87 T'bird. I think they're called the "snowflake" wheels. They have the 35mm offset.
I've been told they fit the 87 Merkur with stock suspension and brakes. Tires I have are 215/45/16
So, do they fit without rubbing? Do I need a spacer or different lugs?
-- Dan
Dan from Illinois
87 Merkur Xr4, 5 spd, White, Summer driver
74 Mercedes Benz 450 SEL, Daily driver
78 Mercedes Benz 450 SEL, MegaSquirted, alcohol, project car
88 Chevy Van G20 Conversion
Re: 89 xr4ti
Post by John Brennan » Sun Nov 25, 2018 1:15 pm
My prediction is that they will-- but try them on, and see.
Oh-- and I think you will need lug nuts for those wheels, but call Tire Rack or a good shop for that angle data.
Re: 89 xr4ti
Post by merkurdriver » Tue Nov 27, 2018 3:24 am
