Heater blower motor not working
Choochoochoo
Post by Choochoochoo » Tue Nov 03, 2015 10:18 am
So I just bought an 85 xr4ti knowing that it has a few minor issues. One of which being the blower motor for the heater and a/c doesn't work, the driver side window doesn't work, and the dash pad is pretty much shot (cracked like crazy). Anyway, the dash pad doesn't concern me at this moment, right now I'm more interested in getting the heat working. I haven't been successful in finding a new blower motor yet, anyone have any ideas where I can get one? The guy I bought it from said he was in the process of eliminating the a/c, which I'm ok with, and that I could get a new "box" with just the heater core and a fan. I would be totally ok with going that route if anyone could point me in the right direction that would be much appreciated. I'm new to these cars, but have always been interested in them and I'm hoping to have this one around for a very long time!
2008 Mercedes Benz R320CDI
1985 Merkur XR4Ti
ford.scorpio
Re: Heater blower motor not working
Post by ford.scorpio » Tue Nov 03, 2015 11:47 am
This might be another option if you eliminate your AC stuff......
Have those if you need them & my contact info is in the following link as well......
viewtopic.php?f=27&t=22286&hilit=euro+blower
Choochoochoo
Post by Choochoochoo » Tue Nov 03, 2015 5:36 pm
Any suggestions on how to attempt a revival of the motor before I spend money on a different unit? Just trying to save money for some suspension currently..
1985 Merkur XR4Ti
ford.scorpio
Post by ford.scorpio » Wed Nov 04, 2015 9:55 am
Since you are looking for a new/used blower motor, you have already verified that all fuses/relays/switches/coil are in good shape and it is indeed shot/seized blower motor?
Do you have a shop manual? If not, there are hard copies floating on evilBay or mc2 racing has CD/digital version available....
Choochoochoo
Post by Choochoochoo » Wed Nov 04, 2015 1:28 pm
The guy I bought it from told me it was likely seized from sitting for so long. I haven't had a chance to actually tear into it yet as its at my parents place and I haven't been able to get there and get it registered. I will check all the fuses before I start the tear down, I'm just looking for any advice on how to go about this before I start. I do not yet have a service manual, but will hopefully soon have one.
1985 Merkur XR4Ti
mhamilton
Post by mhamilton » Wed Nov 04, 2015 8:57 pm
So, the blower does not come on at all? It's and easier fix if it blows only one speed (as in on high).
"Head for the Hills, the Town of Lompach is Under Water!"
In XS 7
Post by In XS 7 » Wed Nov 04, 2015 9:47 pm
If the blower is bad we have a member here who can rebuild it.
Choochoochoo
Post by Choochoochoo » Wed Nov 04, 2015 10:51 pm
No fan at all, it currently doesn't work. Like I said above, I haven't gotten to tear into it yet, so I'm not sure if it's frozen or non functional...
1985 Merkur XR4Ti
Post by Mike McCreight » Thu Nov 05, 2015 10:12 am
Seriously, you're going to be needing a shop manual anyway, so start there, I typically ship one free with any purchase. They're available all over. First think I'd check is the ground. The EVTM supplement to the manual shows the ground points.
There's 2 main failure points, a thermal limiting switch, like in a hair dryer, the contacts fail, and the brushes wear out, or after 20+ years, hang up in the housings.
There's the shop manual approach to getting at the motor, and the backyard method. 1st way involves removing the whole housing, the 2nd, cutting it straight down from the opening where the "resistor" pack is, and removing the motor by removing about 5 screws in total. The 1st method, while being the purists approach, involves a LOT more fasteners and time.
eaton53
Post by eaton53 » Thu Nov 05, 2015 11:44 am
Mike McCreight wrote:There's the shop manual approach to getting at the motor, and the backyard method. 1st way involves removing the whole housing, the 2nd, cutting it straight down from the opening where the "resistor" pack is, and removing the motor by removing about 5 screws in total. The 1st method, while being the purists approach, involves a LOT more fasteners and time.
I used the backyard method in my old 85' XR.
Dang thing chucked several of those resistors. Actually, that was the first thing I thought of when I saw this thread.
'89 XR4Ti
Post by Ed Lijewski » Thu Nov 05, 2015 1:44 pm
Resistor in a sense but correctly a thermal fuse (breaks if over set temperature).
YMMV 8)
Post by Mike McCreight » Thu Nov 05, 2015 6:52 pm
Yup.
The little bullet shaped thing is a thermal fuse.
There's also a device on the motor itself.
Whenever I have a blower motor apart, I bypass the thing.
Post by Ed Lijewski » Fri Nov 06, 2015 7:02 am
Video: Vauxhall Zafira fires: 220,000 cars to be recalled; chairman ...
The Telegraph › uk › ... › Motoring Video
Mobile-friendly - 1 hour ago - Vauxhall chief Rory Harvey says Zafira fires caused by resistor and fuse in heating system, and ...
YMMV 8)
Post by my8950 » Fri Nov 06, 2015 1:54 pm
Motor is seized meaning it doesn't spin when you turn the blower switch in the car on?
If that is a yes, then check fuses and relays as mentioned.
Otherwise, what about removing the underhood connector and putting power to it from the battery?
That will tell you if it is seized or not.
My car has no blower switch on the interior, so technically my blower doesn't work either.
Post by Ed Lijewski » Fri Nov 06, 2015 3:01 pm
There is no relay in the blower power circuit; a #30 amp fuse protects it.
YMMV 8)
