crank shafts pulley removal and carbon canister
intimidatorj
Post by intimidatorj »
Okay,guys I'm in the process of tearing the top end of the motor down as we speak and having problems getting the crank shafts pulley off first I can't get the bolt out with just elbow grease going to try and impact in the next few days and also what pullers have you guys used to pull it off???? And has anyone ever just left out the carbon canister if so pros and cons ? Will everything still work properly
tcwell
Re: crank shafts pulley removal and carbon canister
Post by tcwell »
Use a breaker bar on the crank pulley, jammed into the ground and kick over the ignition a few times with the fuel pump fuse removed.
-Tom-
Don't believe everything you think
tcwell
Post by tcwell »
Also, you don't need a puller to get the pulley off. Mine hadn't been off in 30 years and just giving a few friendly whacks with a dead blow hammer knocked it off.
-Tom-
In XS 7
Post by In XS 7 »
tcwell wrote:Use a breaker bar on the crank pulley, jammed into the ground and kick over the ignition a few times with the fuel pump fuse removed.
X2 on that, also if I remember correct, the bolt is left thread, so it will get lose in the direction where a normal (right thread)bolt will tight. :cheers
merk23literturbo
Post by merk23literturbo »
It is a normal thread, not left handed thread. Lefty loosy, righty tighty.
In XS 7
Post by In XS 7 »
Thanks for the confirmation. :notworthy
There does exist a Rotunda tool specifically designed to remove the crank pulley. It works very well for a stubbornly seized pulley.
intimidatorj
thhanks everyone i guess ill have to hook everything back up to get it to break loose lol and has any of you guys left the carbon cannister off ?
xr89
Post by xr89 »
intimidatorj wrote:thhanks everyone i guess ill have to hook everything back up to get it to break loose lol and has any of you guys left the carbon cannister off ?
Yes, with no ill effects. Left the line in place.
If an interference issue is your reason for removal (intercooler piping?), and you would feel better keeping it, you could always relocate it to the back of the car with a small air filter.
My car is just like my girlfriend...
loud and temperamental.
Ben
Post by thesameguy »
Capping the lines will result in pressure building in the tank, and deleting the canister and connecting the evap line straight to the intake can result in gas vapors accumulating in the engine bay or moisture making its way into the tank. It's really not advisable to remove it.
intimidatorj
okay ill probably just leave it i was just curious i havent ever dealt with te canister style befiore didnt know if it was a ave to keep or not i shouldnt have any interference were it sits for intercooler tanks all tese tips are very hepful
intimidatorj
and dose any one know the exact size of the crank shaft pulley bolt ?? i have a socket that fits it with a lil playuu but dont twant to take a chancecs in rounding it off
Veloce06
Post by Veloce06 »
You can do it that way or just apply a generous amount of heat to the bolt and then use your impact. Should come right off.
Brian Blater
1967 Mustang Coupe - Little Red Clone Project
1985 Mustang GT Conv - the someday project
1988 Merkur XR4Ti - needs some work
2002 BMW M3 Convertible
Heat on that bolt will make it expand...and more difficult to remove.
YMMV 8)
NiggyMerk
Post by NiggyMerk »
Ed Lijewski wrote:Heat on that bolt will make it expand...and more difficult to remove.
YMMV 8)
The heat will also help loosen any crud or loctite.
The trick is to heat it, let it cool then hit it with the impact.
1987 Xr4ti (Rosso Red) - LA3, Big VAM, Cossie exhaust housing,
Cosworth 2wd IC, Turbo back 3" exhaust with Magnaflow muffler,
TC rear disc brakes
Nick
