Pick n Pull time!
DialM4Speed
Pick n Pull time!
Post by DialM4Speed » Sun Feb 14, 2016 3:31 am
Looks like there's a somewhat fresh TC at the local pick n pull so I'm heading to see if there's anything good left on the carcass. I'm looking to start gathering parts for a T-5 swap. This isn't happening soon just want to start collecting bits. Unfortunately after reading many posts and the page on the Merkur Encyclopedia I must admit I'm completely confused. Besides the transmission what else should I grab? Any suggestions would be appreciated.
86 XR4Ti - Port 'N' Polished SVO head w/ big exhaust valves - Ported E6 manifold - 3" Sac Mustang downpipe going into a Catco highflow cat & Magnaflow 3" inlet with dual 2.5" outlets!
In XS 7
Re: Pick n Pull time!
Post by In XS 7 » Sun Feb 14, 2016 5:31 pm
You can fine a great info about the things you will need here:
http://www.merkurtech.com/merkurtech/te ... tem038.php
:cheers
DialM4Speed
Post by DialM4Speed » Sun Feb 14, 2016 5:51 pm
I completely forgot about that site thank you very much!
Post by DPDISXR4Ti » Tue Feb 16, 2016 1:49 pm
What year is the TC and does it actually have a T-5 rather than A4LD? I would only consider a WC T-5 from a '87 or '88. Frankly, the better donor, if you want a 3.97 T-5, is a '91 - '93 2.3 Mustang since it will have some of the later improvements. Also, it likely won't have been beat on as much as one from a barge-heavy T-bird.
Also bear in mind the TC will have a hydraulic clutch, so the bell is different. A couple people have fabbed up hydraulic clutches in a Merkur, but obviously that is more involved.
Post by thesameguy » Wed Feb 17, 2016 4:36 pm
Indeed what year! I have been looking for a spare LA3! :)
