The Merkur Club of America Forums • Large NPR intercooler piping
Page 1 of 1
Posted: Mon Feb 22, 2016 10:26 am
by whitelx
Anyone using a large NPR intercooler with a stock location throttle body? I'm curious what piping and couplers you used to make the connection from the intercooler to the throttle body. I have a fabricated 120 upper that i have been having a lot of issues with cracking at the welds. I'd like to switch to a gutted stock upper intake to solve this and a couple other issues.
I've seen it with SVOs, Mustangs, and T-birds, but they have a lot more room between the radiator and the front of the engine and their setup won't work.
Re: Large NPR intercooler piping
Posted: Mon Feb 22, 2016 11:03 am
by timandsam
I am running that setup now.
2.25 x 3 90° silicone at the TB
2' aluminum tube 90°
3" straight silicone coupler
a 4"ish piece of 3"aluminum tube
3" silicone 90° from there to the IC
It gives about 3/4" of clearance between the tubing and the aalternator pulley. I am only running one belt...
Posted: Mon Feb 22, 2016 3:30 pm
by whitelx
Thanks,
That's a huge help. I'm wondering if I should do 3" or 2.5". 2.5" would probably offer a little more clearance. I suppose I could see how difficult it would be to move the engine back with the Chuck mounts I am using to offer up a little more clearance.
The outlet on the NPR is 2.75, did you just clamp down on the 3" elbow?
Posted: Mon Feb 22, 2016 9:46 pm
by timandsam
I just checked. The elbow at the intercooler is a 3" × 2.75" 90°.
Posted: Tue Feb 23, 2016 11:42 am
by DPDISXR4Ti
I recently posted this in the "Junkyard Shopping List" thread...
'03 - 11 Saab 9-3 Turbo
- Top air-charge hose - 2.75" w/ 90-degree elbow to 2" - Saab p/n 12785081 (Might be useful when using NPR Intercooler)
Posted: Tue Feb 23, 2016 1:37 pm
by merkurdriver
This is the big NPR with a 90° intake. We are making 90° intakes again if you want to go this route http://www.merkurdepot.com
Is anyone running an NPR with stock headlights? I've always wondered if it would fit OK with the stock inner light brackets still there...
Posted: Tue Feb 23, 2016 2:35 pm
by In XS 7
merkurdriver wrote:Image
I have the stock head lights and large NPR IC, no problems right now, but I will put the mustang head lights back on the car very soon and I think it'll be ok too.
Posted: Wed Feb 24, 2016 6:35 pm
by merkurdriver
Thanks for the info Miguel !
Posted: Tue Mar 08, 2016 9:24 pm
by mikek340403
What radiator are you using with the intercooler?
Posted: Fri Mar 11, 2016 12:47 am
by merkurdriver
mikek340403 wrote:What radiator are you using with the intercooler?
www.merkurdepot.com "shorty" radiator
Posted: Fri Mar 11, 2016 2:00 am
by In XS 7
http://www.merkurdepot.com "shorty" radiator
Me too. :cheers
Posted: Sun Mar 13, 2016 4:52 pm
by my8950
I think that shorty radiator is probably enough to keep the car cool all times of the year??? Considering they never really get too hot, stock, do they?
Another question I had, could one of you guys with the NPR I/C post a picture of the part number on the IC? Usually says Tokyo Radiator, correct?
Do you guys with this combo still have the front and rear fan, A/C?
Posted: Mon Mar 14, 2016 10:37 am
by Choochoochoo
Not trying to hijack anyone's thread, but what year mustang lights? I could definetly use some better headlights..
Posted: Mon Mar 14, 2016 10:40 am
by merkurdriver
my8950 wrote:I think that shorty radiator is probably enough to keep the car cool all times of the year??? Considering they never really get too hot, stock, do they?
Guys in blazing AZ summer heat report cooler summer temps with the shorty rad vs the stock rad. :cheers
The big NPR IC takes up the same real estate that the AC condenser and front fan do, so those have to go
Posted: Mon Mar 14, 2016 11:36 am
by my8950
Sounds good Mike!
I just need a part number off the NPR I/C.
