speedometer cable mounting
fh4ever
Post by fh4ever » Tue Feb 23, 2016 7:37 pm
hi all, new here, I have an xr4ti type 9 (maybe '86 model) 5 speed tranny in an Anglia. I cannot seem to understand how the speedo cable is held in to the tranny. I dont have a cable at the moment so I am unsure what the cable end should look like. The tranny has no bolt hole, no threads, no circlip grooves on or near the speedo output. Can someone post a pic of the cable end, and maybe a pic of how the cable is mounted in the tranny? anyone have a cable for sale?
thanks all
mopman93
Re: speedometer cable mounting
Post by mopman93 » Tue Feb 23, 2016 11:10 pm
held in with a spring clip, merkurmidwest for parts or merkurdepot
Post by merkurdriver » Wed Feb 24, 2016 6:38 pm
x 2 held in with a c clip
Have new and used T9 speedo cables on hand in both flavors ( 1 pc standard one and the 2 pc one if you want to run a VSS sensor in line for cruise control or other reasons )
fh4ever
Post by fh4ever » Wed Feb 24, 2016 7:20 pm
thanks folks...since you mention spring clip, a lot closer look (and better light) revealed the groove the "retaining ring" goes in. Merkurdriver...I may need a cable, but at the moment I need to get the tranny back in and see how space is available next to the modified tunnel and crossmember....I think I may have to put a right angle gearbox as well as a ratio adatper to the the stock anglia speedo to read halfway close. A little more research is needed first and then I may need one of your cables. Can you send a pic of the speedometer end of the cable?
Post by merkurdriver » Thu Feb 25, 2016 6:29 pm
Here is a pic of the 2pc cable with the speedometer end shown. (ignore the other end if you ar seeking a 1 pc cable)
Speedo end has the white plastic locking collar
fh4ever
Post by fh4ever » Fri Feb 26, 2016 1:15 pm
just as I suspected...the speedo end will not work for me. I need the threaded "cap" like the other end. might have to have a custom cable made. I had been running a pinto 4 speed, pinto cable, on the anglia speedo with no modifications....not so lucky with the T9. A little research and I may need to get back to you....thanks
Post by merkurdriver » Fri Feb 26, 2016 8:46 pm
The other "side" of the 2pc T9 cable is like how you describe, T9 trans end on one side and the threaded cap on the other side. . . have in stock new and used.
If you happen to text, PM me your # and I can quickly/easily send pictures of a variety of T9 cable options.
fh4ever
Post by fh4ever » Sat Feb 27, 2016 1:25 pm
pm sent
Post by merkurdriver » Sun Feb 28, 2016 8:46 pm
fh4ever wrote:pm sent
Sent pics and details via text the other day but never heard back - did you receive them?
fh4ever
Post by fh4ever » Mon Mar 07, 2016 9:29 pm
yes ..check with paypal.
