Just got it today
Re: Just got it today
Post by thesameguy »
Just be sure you remove the resistor wire from the wiring harness to the in-tank old pump. Some people have reported, well, fire when failing to do that. The increased amp draw of the pump could result in the resistor section overheating. ;)
In XS 7
Post by In XS 7 »
I got mine from mc2racing it came with everything to use it in the XR.
Also here are the instructions to do the swap in the best and easy way possible.
http://www.mc2racing.com/tech/20050902b/index.html
:cheers
Didn't even think to check MC2. Worth paying the premium - a good bunch to have a relationship with.
abomb1982
Post by abomb1982 »
found this...
soldered those back up annnnnnnnnnndddd...... :( blah nothing so I continue on my search to find the voltage drop but I'll find it... I hope.
abomb1982
Post by abomb1982 »
some other things I did today
fun, fun
abomb1982
Post by abomb1982 »
I have searched for a wiring diagram for the fuel system and only found one generic one for the t-bird. Anyone know where I could find one?
Get the manual on CD from MC2 when you get the fuel pump. ;)
helios
Post by helios »
Love that metallic red. :cheers
-Chris S.
'76 Mk1 Swallowtail / '87 XR4Ti slickroof / '93.5 Corrado SLC / '94 SVT Cobra / '95 Escos / '96 GTi 2.slo
abomb1982
Post by abomb1982 »
:headbang I WIN!!!! :headbang
abomb1982
Post by abomb1982 »
I moved to putting the interior back together after super cleaning it :D
abomb1982
Post by abomb1982 »
So I noticed the other day there was a tag on the extra turbo that came with the car. I am pretty sure if I am deciphering junk yard correctly its out of a turbo coupe. Any though on what I should do with it?
abomb1982
Post by abomb1982 »
So here what I have been up to so far
pulled the radiator
water pump looked well i didn't like it.
still have a bad valve cover leak, the bolts actually back themselves out? I'll deal with that next
abomb1982
Post by abomb1982 »
So I had to pull the valve cover to see what was going on. the cork gasket was well not so good anymore. Doing some research I ordered the ford pcv valve and the ranger valve cover gasket. Having the top torn down this far i was wandering if anyone can think of things to do before I reassemble on Thursday. I am even considering a bigger cam.
abomb1982
Post by abomb1982 »
uuumm well, good talk, goooood talk. :(
eaton53
Post by eaton53 »
Looks like you've got some work ahead of you. Hopefully you get it back on the road soon.
No tips from me, though. I bought my car 100%, no work required beyond polishing.
'89 XR4Ti
'89 Scorpio
