EGR EXhaust Fitting
JimG
EGR EXhaust Fitting
Post by JimG » Sun Jul 03, 2016 9:34 pm
Anyone know what the thread size is for the EGR pipe fitting in the exhaust manifold is? I'm deleting EGR and will need a plug for this.
Jim Gosses
Choochoochoo
Re: EGR EXhaust Fitting
Post by Choochoochoo » Mon Jul 04, 2016 4:54 pm
I think someone said 1/2" NPT? But I could be wrong...
2008 Mercedes Benz R320CDI
1985 Merkur XR4Ti
Post by merkurdriver » Mon Jul 04, 2016 11:57 pm
Yep, its NPT thread commonly found in the local hardware store plumbing department. Mine has one of those plugs with the "square" on the head
reddy2300
Post by reddy2300 » Tue Jul 05, 2016 9:46 am
And what do you use to seal it? Or is that even required?
1987 5-speed XR4ti-70K mile "barn find", Rosso Red, Grant wheel, short throw shifter, PE/big VAM, 255lph pump, 3" Stinger/Magnaflow exhaust, MD "shorty" radiator/IC, fake BBS wheels, Koni Yellows, Rapido sway bars, poly/aluminum bushes, Gillis valve,
ford.scorpio
Post by ford.scorpio » Tue Jul 05, 2016 10:41 am
x2 1/2in
Post by thesameguy » Tue Jul 05, 2016 3:36 pm
NPT threads are self-sealing by design. You could probably use a little ultra copper RTV in there if you wanted to be sure, or (my choice), some high-quality anti-seize so you can get it back out later. :)
Choochoochoo
Post by Choochoochoo » Tue Jul 05, 2016 5:28 pm
Why on earth would you want to put the egr back on? :lol:
1985 Merkur XR4Ti
Post by John Brennan » Tue Jul 05, 2016 9:57 pm
Smog testing-- some areas require it to not only be installed, but actually test its function.
And just because they don't smog test in your area now, doesn't mean they won't in the future... or that someone who buys the car won't need it.
Post by thesameguy » Wed Jul 06, 2016 6:34 pm
All true!
But, really, why make something more difficult to take apart in the future when it costs virtually no money and no time to help ensure you'll be able to. Better to do it and never need it than not do it and wish you had.
Post by Ray » Thu Jul 07, 2016 7:23 am
Also is a convenient port for EGT sensor, external gate, etc.
