Hydraulic clutch
DAReese
Hydraulic clutch
Post by DAReese » Sat Jul 16, 2016 10:13 am
Trying to decide whether to go hydraulic after the firewall gave way and I've gone through five clutch cables in a year.
How hard is the conversion? I'm guessing I'd have to collect the parts from a turbo coupe and get after market pedals from somewhere.
I've only found two people who have done it. Is it really that hard?
merk23literturbo
Re: Hydraulic clutch
Post by merk23literturbo » Sun Jul 17, 2016 2:23 pm
Another option is to Panel Bond a metal panel to the broken area. It's stronger than welding due to surface area contact. Just FYI.
DAReese
Post by DAReese » Mon Jul 18, 2016 3:32 pm
merk23literturbo wrote:Another option is to Panel Bond a metal panel to the broken area. It's stronger than welding due to surface area contact. Just FYI.
Thought about that, at least adding a patch but cable keeps pulling through although that might possibly be made worse by flexing firewall. Thoughts anyone?
I've got the firewall on my parts car, and I can get one form a pull apart, so I could sandwich them on both sides on the firewall.
mopman93
Post by mopman93 » Tue Jul 26, 2016 7:17 am
It's worth it. Burton power sells a pedal box modified with a hydraulic slave. It may be on an exchange basis. Having done a setup with an aftermarket pedal assembly, and seen the amount of work a friend of mine did with an aftermarket setup, I would go with the burton power.
If you are using a turbocoupe slave, you need some -3 adapters available from Summit and a 3/4" master.
That being said, you should address your firewall issues first. By going hydraulic you're not replacing any force, just displacing it.
