Merkur Flange Yoke To Mustang Driveshaft
merk23literturbo
Re: Merkur Flange Yoke To Mustang Driveshaft
Post by merk23literturbo »
Is that a 3" or 3.5" diameter driveshaft?
thanks
James
It's 3 inch.
James Wieler
Post by James Wieler »
thanks
James
It's 3 inch.
Did you calculate its critical speed?
merk23literturbo
No.
James Wieler
Does anybody know what u-joint the Aerostar driveshaft uses? Is it 1310 and thus compatible with this flange yoke? I have an Aerostar DS that is 52" long (needs to be ~47 u-joint to u-joint) but I can get it cut down.
thanks
James
James Wieler wrote:Does anybody know what u-joint the Aerostar driveshaft uses? Is it 1310 and thus compatible with this flange yoke?
It depends on the year of the Aerostar. The early ones used a crimped-on yoke with a "different" U-joint. The later ones with the welded-on yokes should be 1310.
Even if you have an early Aerostar driveshaft there is a solution in the form of a hybrid U-joint. But you really want the later driveshaft - it's thicker and more readily shortened.
James Wieler
Thanks Brad, mine has welded yokes.
best
James
deaner
Post by deaner »
Back from the dead bump! Is this flange designed to work with the mustang driveshaft or more so for ease of having a custom DS built? Looking at their notes on the product page, they added an inch to centerline and I'm just curious if that inch is making up the differance an adapter would be. Unless I'm reading that wrong?
-Dane-
Wannabe rally driver.
deaner wrote: Fri Sep 28, 2018 4:25 pmIs this flange designed to work with the mustang driveshaft or more so for ease of having a custom DS built?
It's mostly meant for a custom driveshaft, but that could also mean a Explorer/Aerostar/whatever shaft that is shortened.
deaner
Post by deaner »
DPDISXR4Ti wrote: Sun Sep 30, 2018 10:52 am
Good to know. Thanks for the reply.
-Dane-
Matt01
Post by Matt01 »
Is anyone selling these?
Matt01 wrote: Sat Feb 05, 2022 8:28 am Is anyone selling these?
I'm not sure if you can buy directly from Powertrain or if you need to use a reseller of their products. Either way, I'd start with Powertrain and go from there. Everything you need is in the first post.
Feel free to update this thread with your results.
James Wieler
Can anyone confirm the correct length that an Aerostar one piece needs to be shortened to?
Many thanks
James
James Wieler wrote: Sun Feb 06, 2022 2:49 pm Can anyone confirm the correct length that an Aerostar one piece needs to be shortened to?
Many thanks
James
47.5" That assumes stock engine location, T-5, and stock rear differential.
IIRC, 4x4 Aerostar has a 47" driveshaft, which is close enough.
James Wieler
Great thanks Brad, does that also account for this new differential flange?
Best
James
James Wieler wrote: Sun Feb 06, 2022 10:38 pm Great thanks Brad, does that also account for this new differential flange?
That should be inconsequential. It's not like you're adding any sort of spacer/adapter, so required driveshaft length wouldn't change. Orrr, you could just buy this.... :mrgreen:
http://forum.merkurclub.net/forum/viewt ... 27&t=34347
