Fuel line replacement
Chris_12
Post by Chris_12 » Tue Feb 14, 2017 5:31 pm
Lately, I have been working on the upper half of the engine and found sorry looking fuel line connecting the Bosch fuel filter (I think) and the engine. I replaced it how it was, but I am not getting a good seal (ie spraying fuel). Is there a certain fuel line part number that I can get at a parts store? Or maybe a better question, what kind of setup do you have there? Normal fuel hose? High pressure?
'88 Merkur XR4Ti-The Build
'87 Merkur XR4Ti-The Beauty
In XS 7
Re: Fuel line replacement
Post by In XS 7 » Tue Feb 14, 2017 6:58 pm
Maybe you just need the clamps that are special for fuel lines? they are different the the ones at the pic, I just used that fuel line clamps on my XR at the very same location than you (well, with the difference that I removed the whole fuel dampener) and I got no leaks at all, I get the fuel line/hose and clamps from O'reilly's.
:cheers
Chris_12
Post by Chris_12 » Tue Feb 14, 2017 7:01 pm
ah, good point. I didnt even think of different type of clamps.
Post by Ed Lijewski » Tue Feb 14, 2017 7:09 pm
There are small, special O-rings inside each end of the OEM hoses; the O-rings are available on auto parts stores' shelves (~ $8-$9 for fourx two large for supply line,two small for return line.
YMMV ;)
Chris_12
Post by Chris_12 » Tue Feb 14, 2017 8:34 pm
so I got one for ya. I removed the damper (not filter), disconnected a wire connector attached in the front of the intake manifold (front driver corner below the intake elbow mounting), and attached the fuel line directly. Usually, the radiator fan constantly ran (switch issue), and the fuel pump hummed. Now, I noticed the fuel pump hums for about 2 seconds and kicks out and the radiator fan does not turn on; but the car ran and didn't leak fuel. Thats a win I guess.
Post by DPDISXR4Ti » Thu Feb 16, 2017 2:59 pm
Chris_12 wrote:disconnected a wire connector attached in the front of the intake manifold (front driver corner below the intake elbow mounting)
Are you talking about the ground (visible in your pic above) that is attached to the intake manifold? That should certainly be attached.
The priming operation of the fuel pump as you describe - on for 2 seconds with key in on position - is correct and normal.
As for using "universal" fuel hose with hose clamps for this application, that's not recommended. The stock fittings are not barbed, so you risk blowing the hoses off.
Chris_12
Post by Chris_12 » Thu Feb 16, 2017 5:35 pm
Well, I bypassed the damper. No fuel leak now. As for the wire, I got the ground wire. It is behind and not connected to the upper intake. Radiator is now working. It seems with the good comes the bad. Unrelated though. I found my large oil leak. I replaced it with the recommended gasket. I guess either the cover or head isn't flat... Or both
