odd question
abomb1982
odd question
Post by abomb1982 » Sat Apr 15, 2017 10:36 pm
There is a black box on the passenger side frame rail in the engine compartment. just under-ish the air box. It has a plastic line that runs all the way back to I think the gas tank or at least thats where I lose it and a hose running to the air box. I can get a pic but don't have it now and thought maybe someone would jus know....... What is it? I would like to delete it
In XS 7
Re: odd question
Post by In XS 7 » Sun Apr 16, 2017 1:21 am
I think you are talking about the charcol canister.
Re: odd question
Post by merkurdriver » Sun Apr 16, 2017 1:18 pm
In XS 7 wrote:I think you are talking about the charcol canister.
Agreed
( x 2 )
abomb1982
Re: odd question
Post by abomb1982 » Sun Apr 16, 2017 9:52 pm
that is exactly what I thought it was. can I delete it? and what do I do with the line if so?
Re: odd question
Post by John Brennan » Mon Apr 17, 2017 8:23 am
Check local smog laws.
Re: odd question
Post by thesameguy » Mon Apr 17, 2017 6:56 pm
I DON'T KNOW WHAT IT IS OR WHAT IT DOES BUT I DON'T LIKE IT.
abomb1982
Re: odd question
Post by abomb1982 » Tue Apr 18, 2017 8:16 am
maybe I should re phrase my question. Is there a proper way to delete it or can you just pull it and cut the line?
Re: odd question
Post by thesameguy » Tue Apr 18, 2017 1:35 pm
Maybe you should leave it there to prevent gasoline vapors from getting into the air we have to breathe. There is absolutely nothing to be gained from removing it.
DAReese
Re: odd question
Post by DAReese » Sat Apr 29, 2017 12:11 pm
thesameguy wrote:Maybe you should leave it there to prevent gasoline vapors from getting into the air we have to breathe. There is absolutely nothing to be gained from removing it.
Weight loss. It has to weigh at least half a pound.....
Re: odd question
Post by thesameguy » Sat Apr 29, 2017 4:20 pm
True, and tbh I had not actually considered that. I use only three lug nuts per wheel to cut weight, but maybe dumping the canister would have been a better approach. Food for thought. Thanks!
Re: odd question
Post by Esteban » Sat Apr 29, 2017 10:14 pm
It can be removed. It just means the fumes from the gas tank are released into atmosphere instead of recirculating back into the intake. If you smog the car, they will look for that so keep it handy for then.
Re: odd question
Post by my8950 » Sun Apr 30, 2017 2:25 pm
I think every XR and others I've owned usually have the hose to the canister cut/torn/missing before I even get the chance to look.
The XR hose is made from paper towel roll, not sure what the thought process was behind that as far as holding up to the elements.
Re: odd question
Post by Ed Lijewski » Sun Apr 30, 2017 2:49 pm
So....replace with a new one. (BTW, that kind of hose was used on most if not all cars made earlier (not a unique fitment to XRs).
Regular/periodic servicing...
Re: odd question
Post by hEaT » Sun May 14, 2017 9:40 am
I have mine just dumping into the frame rail.
If you remove it, DO NOT CAP THE LINE. It must be allowed to breathe.
