Newer spare tire/wheel option - Ford Fiesta
Post by DPDISXR4Ti » Sun Jul 30, 2017 10:09 am
By now most of the original spare tires have cracked and split and died. Many of us have replaced them with Saab 900 and 9000 spares, but even those are getting old now, the newest being over 20 years old now. While looking for something else on eBay this morning, I stumbled across a 2011 - '16 Fiesta spare tire. Bonus points for it being an Aluminum wheel; negative points for it being only a 15" wheel, so it may not clear the typical big brake upgrades.
Has anyone tried one?
jkxr4ti
Re: Newer spare tire/wheel option - Ford Fiesta
Post by jkxr4ti » Sun Jul 30, 2017 11:01 pm
We just bought a steel fiesta spare this summer for Joe's car.
It has Stock brakes so no experience with it on a large rotor car.
It did fit as expected and as I recall it was closer to the diameter
of the factory tire OD than the original mini spare was.
Plus it did fit the factory spare tire well and was hubcentric.
Post by thesameguy » Mon Jul 31, 2017 12:06 pm
If you have the wheel, why not just replace the tire? Tirerack sells them, I'm sure others do as well.
Personally, I dumped the spare and switched a "mobility kit" from a... Hyundai? Compressor, goop, bag. Saves weight, saves space, and it's nice having a compressor in the car. I have low tires way more often than flat tires. Last flat I had was maybe 14 years ago.
DAReese
Post by DAReese » Mon Jul 31, 2017 12:29 pm
thesameguy wrote:If you have the wheel, why not just replace the tire? Tirerack sells them, I'm sure others do as well.
Because you can always replace a flat with a spare. You can't always fix a tire.
DAReese
Post by DAReese » Mon Jul 31, 2017 12:31 pm
DPDISXR4Ti wrote:By now most of the original spare tires have cracked and split and died. Many of us have replaced them with Saab 900 and 9000 spares, but even those are getting old now, the newest being over 20 years old now. While looking for something else on eBay this morning, I stumbled across a 2011 - '16 Fiesta spare tire. Bonus points for it being an Aluminum wheel; negative points for it being only a 15" wheel, so it may not clear the typical big brake upgrades.
My understanding is the spare will fit on the rear tire even with the disc upgrade. That just means with a front flat you need to change two tires, back to front and spare on the back.
Post by thesameguy » Mon Jul 31, 2017 1:00 pm
DAReese wrote:Because you can always replace a flat with a spare. You can't always fix a tire.
I guess... but with one exception I have never damaged a tire to the point it was undrivable. Every other flat I've had would have been solvable with air if I'd had it. If I ever get there again, I've got a cell phone. Given that most new cars don't even have spares, sure seems my experience is more the norm than the exception. :shrug:
DAReese
Post by DAReese » Tue Aug 01, 2017 12:12 pm
The issue is when you are in an area with no cell reception. They still exist. But same here, short of sidewall splits or blowouts, most flats can be fixed at least temporarily with a can and air, sometimes with just the can itself.
Post by merkurdriver » Tue Aug 01, 2017 3:38 pm
The stock spare fits over the Merkur Depot rear disc brake kit...I'm not sure it will fit over the other (bigger) real brake kits
