Drove to the inspection station, opened the hood and there was oil everywhere. It's on the right side of the engine, dripping down off the hood at the back. I've changed the oil seal on the breather and the rocker box cover, but I still think it's coming out of the breather under pressure. I drove home between 2/3k keeping off the boost and no oil spill occurred!
Any clues?
Craig.
Edit (Just read in a forum post that it maybe coming out of the dipstick pipe under load)
Oil leak
- Mike McCreight
Re: Oil leak
Still using the cheezy factory oil feed to the turbo? They can develop hairline cracks that open under higher rpm/oil pressure.
Same for the oil pressure sender, if that's still in play.
Re: Oil leak
it also goes without saying not to drive the car like that. hot turbo and oil spray = fire.
Re: Oil leak
Check the pressure sender, I had a leak from it since it split down the middle.
Oil was pouring out of it, not hard to find.
Re: Oil leak
Using a Motorcraft PCV? All the rest are junk... this is a common issue.
Re: Oil leak
My friend's XR4ti burned to the ground because the oil feed to the turbo sprang a leak and sprayed oil on the exhaust manifold.
Two weeks ago, my oil return line from the turbo on my XR4ti sprang a leak and began spraying oil on the exhaust manifold. I stopped driving it before it could catch on fire.
The high turbo boost of these cars pressurizes the crankcase and makes leaks from any weak spot very common. And leaking oil on a hot manifold makes engine fires a real hazard.
The lesson is to periodically check for oil leaks and fix any you find immediately. Make sure your PCV valve is working properly and check it every 10,000 miles.
Dan from Illinois
87 Merkur XR4ti, 5 spd, White, Summer driver
2014 Ford Focus SE, ECU tuner.
- nathankershaw
Re: Oil leak
I've had an oil pressure switch gush oil...PCV is always a good & cheap thing to change (Ford only)
I'm definitely gonna check my turbo oil supply lines now I've seen this thread!!
