Narrow radiator instead of shorty...
Longitudinal
Post by Longitudinal »
I'm considering buying or building a radiator that allows the charge tubes routing to and from the intercooler to go beside the rad instead of over top of it like a shorty. I have not gone out to measure yet.
Thoughts? I can weld anything I need to. I would actually prefer a tankless radiator core if anybody knows where to go for one. Finding intercooler cores seems to be much easier, but it is much easier to find and fit a completely built intercooler than it is for a complete radiator.
Re: Narrow radiator instead of shorty...
Post by thesameguy »
You'd want to measure to be sure of what you're gaining or losing, but conceptually I think it's a good idea. That is how most cars with factory FMICs are done, often with trapezoidal end tanks to maximize the surface area. I am definitely going to need to replace my shorty at some point - if I can before summer - and this is one of the avenues I wanted to pursue.
Customizable radiator cores are indeed hard to find - I think that's why the MD radiator is (I believe) based on an intercooler core. I don't know what kind of minimum volume is needed, but I know the folks at Champion Radiator have done on-demand radiators for other cars. I had intended to talk to them when the time is right. I'd definitely be interested in what you find.
Longitudinal
Right, and I don't mind losing a little volume and/or surface area if I have to, but I think I can get away with an increase at least in volume if not volume and area. I want to be able to use dirt cheap and wide temp selection VW fan switches mounted inside the rad tank.
I would be surprised if an intercooler core made a good rad core.
I believe you are correct - both radiator shops I have had modify the MD radiator commented that it's not the most efficient configuration for fluid:air. I've not had any actual problems and it does a *fine* job even in NorCal summer heat, but it's insufficient for my mountain climbing past time. It's been on my to-do list for a long time, but last summer was very warm and I made an unusual number of trips up to Tahoe so it's still fresh in my mind. Nothing ruins a nice drive like aborting a pass due to skyrocketing engine temps. ;) Plus, I wanna have a solution if/when I actually get this track car built. I was gonna use a radiator from a 9-3 (since that's where the engine will be coming from) but inexplicably the radiators for manual transmission cars are $400 vs. the $120 for automatics... I'm not spending $400 on a stock radiator. That's insane.
Longitudinal
What would make the manual unit necessary?
Stay tuned. If my solution is finished in time to help you, maybe I can build an extra copy for you.
Nothing, except some (unused) ports for the transmission cooler and a slight resultant loss of volume. :)
thesameguy wrote: Thu Dec 14, 2017 7:00 pm
Our original radiators were indeed made with a bar / plate intercooler core. Our new radiators are made with a tube / fin radiator core.
That's really good to know - thanks!
Depending on how this alternative project goes, I may very well give one of the new ones a shot!
Longitudinal
thesameguy wrote: Thu Dec 14, 2017 8:01 pm Nothing, except some (unused) ports for the transmission cooler and a slight resultant loss of volume. :)
That's just a squirt in the ocean. If you feel like dumping more heat into the coolant, plumb motor oil through it.
Post by my8950 »
Do it! I think it would be cool to shorten it up allowing more room for piping.
Considering the way the cars make heat, I'm pretty confident one could get away with a smaller rad.
Longitudinal wrote: Thu Dec 14, 2017 8:58 pmThat's just a squirt in the ocean. If you feel like dumping more heat into the coolant, plumb motor oil through it.
I've already got a sizeable Setrab cooler up front - oil temps are excellent.
Longitudinal
thesameguy wrote: Fri Dec 15, 2017 3:00 pm
That wasn't quite my point. My tongue in cheek point was that you could ignore the trans cooling lines and save money.
DAReese
Post by DAReese »
thesameguy wrote: Thu Dec 14, 2017 7:00 pm You'd want to measure to be sure of what you're gaining or losing, but conceptually I think it's a good idea. That is how most cars with factory FMICs are done, often with trapezoidal end tanks to maximize the surface area. I am definitely going to need to replace my shorty at some point - if I can before summer - and this is one of the avenues I wanted to pursue.
Ellet Radiator fairly close to Mike still does custom work. The only problem is they do autos on an as time is available status now. I talked to the owner about repairing my Hartwood radiator, but didn't want to have it down for an extended period. Now that I got a MD shorty replacement, I can finally get to that with little risk of having it sit for a while.
http://elletradiator.com/services/
I have a couple shops locally that will do custom work - the guys that modified my MD radiator and faux Cossie intercooler are great - but I mentioned Champion because they seem interested & able to cook up a design and knock out 20 copies or so. My local guys - B&M - would do one, but they just don't have the facilities to "productize" a concept.
I may throw in the towel and just do a Cossie clone radiator since it's the *other* easy button (MD option being the first/best). We'll see how rich & how desperate I am once the chill is past. ;)
In all candor, I can't think of any reason why this would be better than the readily-available option. Over-the-top leaves you with a full-width radiator, and allows for full sealing of the perimeter of the radiator opening with minimal fuss-- plus, it leaves you the choice of keeping your A/C condenser with a 2WD Cossie-style IC, or a deeper, RS500-style IC, your choice.
