Turbo Studs! Which ones to use?
Matt01
Post by Matt01 » Tue Dec 26, 2017 1:02 pm
Hey Everyone.
I used Napa cheapo studs when i changed my manifold, and 1 of them has broken off inside, the other ones have loosened up.
What studs/bolts do you guys use on the turbo?
thanks
Re: Turbo Studs! Which ones to use?
Post by thesameguy » Tue Dec 26, 2017 2:22 pm
From manifold to turbo, or turbo to wastegate, or wastegate to downpipe?
Mostly, I use Saab parts.
Post by Mike McCreight » Tue Dec 26, 2017 3:10 pm
SS studs, and double nuts.
Cleat put together kits long ago, been using them ever since. Get the GOOD Anti-seize.
Matt01
Post by Matt01 » Tue Dec 26, 2017 11:31 pm
Its really the turbo to manifold i have problems.
I have seen without reference to it specifically, people using cummins studs.
Post by thesameguy » Wed Dec 27, 2017 1:05 am
After looking, the last time I did this (in '12) I used hardware from ATP Turbo. Been five and a half years, so far so good:
Using the right nuts is just as important as the right studs - they need to stay put but still be able to be removed. ;)
Post by my8950 » Wed Dec 27, 2017 8:51 pm
Cummins stud - 3818823
Nut - 3818824
Gasket - Nissan 14415-4P200
Ford TA-31 sealer
Studs, although I don't think they are really $63...
https://www.amazon.com/Double-3818823-C ... B00HMNKX50
Screw that, see here instead...
http://www.dieselpartsdirect.com/DS3818823
Matt01
Post by Matt01 » Thu Dec 28, 2017 8:13 pm
i think im going to go ahead and pick up those cummins studs.
the long or the shorts?
Turbo
Post by Turbo » Thu Dec 28, 2017 9:06 pm
Nice! what coating is on the manifold? and did it hold up?
'86 Merkur
'96 Impala SS
'05 SRT-4
'08 Hemi Ram
Post by thesameguy » Fri Dec 29, 2017 12:55 pm
Manifold was ported, then ceramic coated in & out. It was done by these guys:
http://performancecoatings.com/
So far, so good.
itking
Post by itking » Wed Jan 03, 2018 4:41 pm
Those nuts look to be copper. Correct?
Ron
1968 Dodge Charger 383
Post by thesameguy » Wed Jan 03, 2018 6:20 pm
Copper coated, yes. Small locking head copper coated nuts. They stay put but come off when they should.
https://www.atpturbo.com/mm5/merchant.m ... y_Code=FST
They are not cheap but well worth it.
itking
Post by itking » Thu Jan 04, 2018 9:49 am
Thanks.
Ron
