I am looking at doing the ranger cam swap. I have the roller followers, but I thought there were also lifters that need to come from the Ranger also?
Can I use the stock lifters from the 2.3T?
Ranger roller cam swap with stock lifters?
Re: Ranger roller cam swap with stock lifters?
It's my understanding that the HLAs are the same in all of the 2.3 Lima engines. However, you need to make sure that the followers are designed for the same size valve stem as your existing engine. Ford changed to a different (smaller) diameter valve stem in the 1995 model year.
Mark
- merkurdriver
( x 2 ) cam and followers are all you need as long as the cam and followers are from a 89-94
Got it!
Thanks guys...
Thanks guys...
