Battery replacement
Merkur
Moderator
Battery replacement
Post by Merkur »
The last couple of batteries I have had were Bosch Group 47. Part number 47-600B. They fit well and look good under the hood. Bosch have discontinued that battery so I am looking for suggestions. The Bosch 96R-590B seems like it will fit although it doesn’t have the bottom hold-down ‘lip’ like the stock battery. The dimensions and CCA specs are close.
Is anyone using this battery or have other recommendations?
Paul
Paul "the Brit" West
Doylestown, PA
mjfpjf
Re: Battery replacement
Post by mjfpjf »
Hi Paul
With six cars I've run through a lot of batteries
I've had my best luck with Interstate
Worst luck with Optima
Die Hard was so-so
Take care
Marty Farber
Marty
(IL)
87 xr4Ti
I usually go to O'Reilly's or NAPA... no big deal.
Post by thesameguy »
I am using whatever battery a 1995 W124 Mercedes E320 would use. Unfortunately I can't read the BCI number in my own picture. :)
I know a friend of mine used a battery in common with a B5 A4 V6 and it fit well.
markley007
Post by markley007 »
I just replace mine but I went with a Duralast gold because of the 3 year replacement free warranty and 5 years prorated . Wasn't too bad in price either 182 out the door.
1986 Merkur Xr4ti
Merkur
Moderator
Post by Merkur »
OK - just to close out this question, I ended up with another Bosch battery and got a pro-rated discount off the new one since it is warrantied for 96 months - 8 years! Thanks for all the suggestions but I wanted one that fit exactly as the OEM one did with the lip and hold-down clamp and the top strap.
Even though the old battery is discontinued, it is replaced with another one which is just about identical in size and has a little better cold performance. Not that I need that.
The new part number for reference is Bosch PJBH5-650B.
Paul
Doylestown, PA
morlynon
Post by morlynon »
Sounds like you made the right decision. My current Interstate battery doesn't give me problems so far.
