Exhaust leak - from turbo downpipe? Need help diagnosing
Re: Exhaust leak - from turbo downpipe? Need help diagnosing
Post by thesameguy » Thu May 10, 2018 9:46 am
Then you're not using enough, not using it often enough, or not waiting long enough after applying. For something under the car where rust may have welded parts together there may not be anything for it to do, but rust should not be a problem on the turbo.
Post by Ed Lijewski » Thu May 10, 2018 10:51 am
YMMV.
I have two XRs and a Scorpio; removed the down pipe bolts on each once, and also removed tbe down pipe bolts on my parts Scorpio. Spritzed them, and with carefully selected socket (might have used a SAE on one), twisted carefully and removed all without issue.
LITTELHAWK
Post by LITTELHAWK » Sun Jun 17, 2018 11:12 pm
Both of my Xr's leak where the turbo outlet meets the downpipe. From my understanding they didn't use any kind of donut or gasket at that fitting and it just wore down as it got older and used.
